Looking at subs and amps
markw336
I've cut down from 2x 12" Alpine Type-R subs (very good, nice sound) to a single 8" DD in a slotted box - also not a bad sub, but I'm only putting 220W-ish RMS into it (slightly underpowered).
The Alpines definitely gave a smoother bass sound, not too boomy. But that would depend on what sort of music you're into. Either way monoblock amps are the way to go for powering subs, as most can do a 1-ohm load. I had a E-Audio 1000D which is still a good amp these days - the person that scored that for $250 got a bargain!
i just bought inclosed fusion sub and amp combo from Repco and it goes hard.Similar product (same brand) is sold at hyper for less and seems to have same stats just has a slightly different look(green vs grey speakers). I like the switch it comes with that allows you to control the bass instead of having to change settings on H.U etc..
http://www.fusionelectronics.com/car/products/active-enclosures-cp-series/cp-dual-12-active-wedge-enclosure
REPCO
http://www.hyper.co.nz/drive/audio/bass-packs/fusion-BASS-PACK-12-INCH-CS-AW2120-DUAL-SHALLOW/id/5326/product
Hyperdrive
I like my music pretty loud(hence the ringing in my ears every now and then lol) I have 2 15inch Solo Baric kickers powered buy a 1200rms amp.. ;D
It all depends on taste really Id recommend a decent 12inch, amp and door speakers and you will be away grinning..
