Bung Starter Motor?
This morning i went to go into work, as i turned the car over once, it turned as normal, didn't fire, as normal. When cold first thing in the mornig, it normaly takes 1 to get it moveing, 2 to get it started. Allways been like this.
Tried a second time, and just got a "chuff" noise as i turned the key, no RAR-RAR-RAR, noise like you normally get when turning it over. Continues to make this noise as i turn the key.
I suspect a bung starter motor?
I can't roll the car back so that i can do a roll start or anything, as i live down a steep driveway, and can't roll it back enough to get a good roll on (lightweight car my ASS!!)
G
Started sweet as about an hour ago, dunno WTF is up with it.
I assume its on its way out though, will take it apart before i go to CHCH next week and then i can get it sorted without the car off the road for too long.
sounds like what mine was doing. Slame one out of an old non turbo in it - those starters RULE!!
If it just clicks its probably brushes. If it clicks lots after cranking for a couple seconds i'd guess crappy battery terminals or battery
thats my prob....finger tight terminals
Some times even thats not the problem.
It can be the wire that goes from the ignition switch to the starter can be degraded ( gone green etc). It just doesnt allow enought power to go the solenoid. Some times works sometimes it can play up, and you get those funny noises from the starter.
Had that prob on my Vortex 6. A new wire and relay was put in and it starts every time now. starter was never touched.
The relay was hooked up to the ignition wire and new wire run from the relay to the starter or something simmar.
Guest jedi warrior
honestly.....
unbolt the starter... check for burring on the teeth, clean off excess grease. if the teeth are rounded find another starter.
check the earth wires on the starter, also check the earth from the battery to the front of the car.
CHARGE YOUR BATTERY..
also look at gettin brass terminals easy enough swap theyre about $13 from ripco or supersteap.
these will give you better connections and possibly solve your starter issue..
if this doesnt work then im sorry my friend but you have gremlins
Sweet I have heard that, from which models would be best? Early 91 Legy on or earlier
Yeah like others are saying don't forget to make sure the battery's all charged up before you start dismantling the starter motor. ;)
Starter is simple to swap.
Disconnect battery.
Disconnect the power cable that goes onto the starter (10mm spanner) and unplug the small wire thats next to it.
Unbolt the two bolts that hold it onto the back of the bellhousing (14mm spanner)
Drop it on the floor narrowly missing you foot after its bounced off the gearbox.
Put the new starter in the hole thats left by the old one and do up all the stuff you've just undone.
Reconnect battery and then go do some heli's in the Supermarket carpark to celebrate....
Excellent, sounds fun, now to find a new starter motor. lol
It really sounds like its ceased, as its making the same noise as my fan that ceased when it got wet lol.
Sprayed it with CRC for shits'n'giggles just now, will let it soak then try again.
Really pissed off as i have NO food in the house as i've been away for a bit and its too cold to walk anywhere. Pizza Hutt FTW i think.
At $40 a pop you can go through a lot of second hand ones before you get to the price of a new one. Being pessimistic and ssuming a 1year lifespan for each 2nd hand unit, will they outlive the amount of time you plan on keeping the car?
