Amp Question
markw336
hi there i have brought a 12" sony xplod 300 watt rms Sub from repco for 60 bucks this morning and im looking for a 300 watt rms amp to go with it
does anyone know of a reasonable quality one in the 100-200 dollar range otherwise i might have to look at spending more
ok so i have got everything going but now i have a whine from the alternator i believe and goes up and own in pitch and in time with the engines rpm from what i read its cause by having the rca leads and the powere wire being close together but ive wired specifically so this wouldnt happen
any ideas on how to fix this?
simple solution: get a ground loop isolator from jaycar for less than $20
other than that check all your earths, headunit/amp ( even the battery earth for good measure) , did you scratch some paint off in the boot to expose metal to mount the earth too?
Jason (Spark_38) from the welly crew is pretty knowledgeable on car audio installs might be worth giving him a PM
my headunit has the same issue ( sony Xplod) but cant be arsed to fix it until i have a new headunit, then everything is getting replaced @ the same time, have started buying cables etc, started with some triple shielded RCA's
