Aicon won't turn off!
clintondane
Took my Blitzen in to Southern Motorcourt today and had both side rocker cover gaskets done. On the way home i turned the the aircon on and after car had demisted i tried to turn the thing off but it just won't. I can turn A/C off but the unit and fans still stay on. Im totally hopeless mechanically, is it an easy fix or pain in the ass and could it have anything to do with the work that was done on it?
Thanks in advance.
well if its still going with the key out id suggest you disconnect the battery so it doesnt kill the battery over night and take it into the auto sparky in the morning and they will fix the problem
at a guess it will be a relay that has blown which is in the fuse box in the engine compartment
So apparently there's a button on the steering wheel, i went through the whole process and you'll never guess what happened. I discovered a hidden button on top of the steering wheel :o
Haven't had a look in the fuse box yet today but will a bit later. If its a relay problem then bonus, i have a feeling though that the actual off button is munted somehow.
 pl0x said:
sounds similar to the common aircon/heater control fault.
Mine fan stays on unless you set the fan to full & off button doesn't work.
Common air control panel fault then, plenty of replacement ones on trademe just cost like $170-$180
