Generic Idler Pullies
funkytown
Where can you buy these?
I've got the front facing manifold and shifted my alternator across. Its a smooth idler and hard mounted about where the factory alt used to be, and just need to get a smaller one.
I cant work out what the correct term for what im looking for, nor where to find a place that has a catalog of what i want. Its not subaru genuine part so that doesnt help me.
What i have is nearly identical to this, but its used on the serpentine belt.
If you want to know why its becuase i run underdriven pulley wheels on the altenator and crank pulley and it causes the belt return feed off the alternator to run VERY close to the feed side :)
Trust me.. I need a smaller one.
i can sus it out but theres no such thing as generic i put evo one on mine...good ol mitzi parts...
what size do you need? does it need to be offset to fit belt? why do you want a smaller pulley?
idler pulley is the term you are searching for.
like who brad? BNT come to mind - i really just dont know who else might have em!
i've already explained why i need a smaller one above. I'll pull mine off and measure / take pictures tonight.
is it the same as v5/6? i can measure mine up its sitting outside
im going to run the same setup just need to make an adjusting bracket for alt first. i just tensioned it with a bar to old alt adjuster and alt pivot bolt for now with a pulley bolted to the middle. long as nothings touching you should be ok pulleysize wise tho. i bolted various idlers on where you have yours but 50mmish would be smallest i tried so far i think. ill revisit when everything else is ready to go on tho
for random bearings auckland bearings better than saeco normally half the price too theres another joint i just cant think who. that v7 idler looks mint size though and will be readily available. ill get one the next coupla days and check it out for my set up.
So I've measured my pulley.
Its 60mm outside diameter
38mm diameter for the inside bearing bit
And
35mm width
Looks like that one above would do the trick, I think demo is sending me an old one so I can check it mounts right then I'll get a new one, actually 2 :-)
 evowrx said:
Part No: 13073-AA200
FITMENT NOTE Lower Right (of Engine)
FITMENT NOTE Smooth Faced Idler Bearing
OD 32
WIDTH Bearing =34
WIDTH Overall =45
i can do it for $38 freighted new and it will be genuine subaru.
thats a f***en good price!! you would be a handy fella to know ;)
let me know how you get on funky either way. ill still get one in and check but not sure on timeframe.
 rex-leggy']
OD 32
WIDTH Bearing =34
WIDTH Overall =45
now you do...
it is listed as a gen subaru number but ill check tomorrow but should be gen part. aftermarket buy in bulk so can sell half the price of genuine heaps of parts come like that in timing honda/nissan/subaru/mitzi.
