94 RA, with DCCD
what do you mean its in the boot?
I wired the dccd in to mine being non dccd (mike and ben did it mostly) - get an auto cluster and the led set, they are the same and you can wire it up if your clever. the holder and all is identical.
Its a reasonable job to complete - whether its worth it or not is up to you.
you can also just install it and it will run in open mode - which is how they should normally run - it might be a bit more 'taily' than you're used to.
Then take your time getting round to wiring it up :) OR .. get the dccd controller from PBMS for $450 and its a much simpler solution.
its an after market dccd controller made by possum borne motor sport.
if you intend to run a g4 link then ive been told they can control dccd's also.
the box wont go back to its last setting ..... without a controller it will stay in open mode which has a bios of 40% drive to front and 60% drive to the rear, which is why funky mentioned taily.
easiest option is get the pbms controller :) or talk to kaminiko on this forum he was developing his own last time i heard
 GC8E2DD said:
I would probably get a dccdpro controller rather than a Possum Bourne one. I've heard good things about them.
+1 and bit cheaper than the pbms controller, jeff at dccdpro is good guy to deal with
Yep. And you could even make your own controller as Nick is/ was doing if you are good with electricses and logicses. Or as mentioned, it has been successfully done with a Link I believe. There is a mechanical advantage of 35/65 with the older DCCD units, so you will just need to get used to the lighter end of the car (the rear) breaking traction more easily until you have some way to control the diff.
  • 3 weeks later...
