fitting xforce 3" down pipe to gc8
whatchain
just brought a xforce downpipe today. just wondering how straight forward is it when fitting? is there anything i need to know or is it just a simple unbolt and put in new down pipe? also can all the bolts be undone from the top or would i need to raise the car to get to some?
I had a 3" rage a few years back, and the flange was the same size but rotated... and it was also a flat flange I think, no doughnut.
I was pretty pissed of about it and complained... hopefully a lot of people complained and they changed it. No good reason to put
a different flange on.
 evowrx said:
The 3" flange bolts straight to stock cat back but yea flat flange versus stock donut style. I just used a normal 3" gasket not a steel one and it worked till I swapped on a flange style catback.
Yes Ive done it mainly with a twisted downpipe but a couple of times with stock fitment. Dont need the car too high just jack it up and slide under.
You will need a lift. If your car is old it\'s not a "straight swap" (e.g 150kms + on stock exhaust). You\'ll need a dam good socket set with multiple ratchets sizes (to fit in awkward places). It\'s pretty simple to do but is prone to being a problematic repair process. On my old subaru I had to take the down pipe/turbo/uppipe out in one piece as well as the intercooler and air intake, that\'s probably a worst case scenario though.
