Automatic Usage
martin308
It\'s a valid question. I remember way back when, my driving instructor said best to put in neutral at the lights, as a safety measure more than anything in case foot slipped off brake plus in theory it uses less gas (like, a tiny, tiny bit less)
No different to sitting in gear with your foot on clutch I suppose. It stuck with me, I always put it in neutral at the lights.
 martin308 said:
I was mainly asking around the wear and tear on the car and petrol usage, my googling lead me to believe that its split pretty evenly between people thinking D is better than N and vice versa.
I couldn\'t find any proof behind either position though
Then problem solved! do what you want and concentrate on something more pressing... like "how the hell do you launch an auto?"
Easy peasy,
ESP "off"
Left foot on brake
Transmission in Sport mode
Hard on gas
Revs build up to 3000 rpm
Release brake
Whooosh !
;D
Otherwise, put in D, hold on brakes until you reach torque converter stall point (where torque converter is most efficient at multiplying torque), release brakes, zooooom.
 madmike']
[quote name='neodowd said:
yes put it in neutral at the lights just like a manual. I put my foot on the break whilst changing into gear from a stop start in my auto makes change smoother
WTF??
What don\'t you understand about what I said?
 neodowd']
WTF??
Mike\'s not too good with written or spoken language... so I will explain. I believe he was expressing some mystification at your statement about changing from N to D while completely stationary being smoother with your foot on the brake.
