Snail Billet Compressor Wheels
Stoffa
Just got a message from snail turbo, the wheel is on its way. turns out the big 16g is extended tip as well, the same design as garretts gtx wheels.
Ive had a bit of a search but cant find many results online.
Does anyone know if the compressor cover off an evo td05 big 16g will bolt onto a subaru td05? Need to round up some parts to make it work
I dont know vorigan will but I thought evo 1 2 and 3 all had different variations of comp wheel 3 being the best. They all run slightly different numbers first 2 of second set by bad memory and vary in cfm. Not sure how subaru compare but they are mhi arent they I figured they werent big 16g for some reason? I have asked a couple of times on here though no response. Blade design/surface area/shape/blah matters as much as size does it not anyways?
This could be utter bullshit dont take it for gospel.
 random quote from my notes said:
xtian
put it this way,
EVO is not Subaru, so what they put into evos is irrelevant to RAs.
However, early WRX/RA/RA STi use MHI\'s TD05H Turbo housings - this is 100% correct.
But, the compressor housing on those turbos is in fact using smallest 16G wheel
So, on impreza we have Small 16G
There is aftermarket, "Big 16G", the compressor wheel is really bigger than of small g.
See the picture
Then, there is sth called "Super 16G", which is put on evo3 - which in fact costs even more than 18G.
I think I found it (the proof that early WRX/RA/RA STi has Small 16G), go here:
http://www.stealth316.com/2-turboguide.htm
See, the MHI Turbo Nomenclature part, and scroll to TD05H-16G-7cm2 :
small 1.830"/2.365" compressor wheel
- number: 49178-05200
- cartridge number: 49178-09090
- repair kit number: 49178-81200
Now, if you look at your compressor housing on an early WRX/RA/RA STi \'s you will find
similar(same) numbers.
Actually,
I have my \'96 16g sitting right here in my office. It\'s got different numbers. 49178-06310
Can you translate that for me?
...I have my \'96 16g sitting right here...
Just measure the compressor wheel then:
The small 16G compressor wheel is 1.83" at the inducer and The Big 16G is 1.89"
thats what I thought, but it does have Big16G dimensions. I did have the choice of quite a few but 18G and 20G wheels looked like exact copies of genuine wheels and dont think I would have tried putting a taiwanese 3071 into an expensive garret core. Think I\'d much rather test the waters with a cheap and cheerful TD05.
if it lets go at 1.5 bar probably the worst that might happen is damage my FMIC core
Put it up on your facebook then :D people read it on there. This is accurate info above then? I didnt read it in full just thought with all the talk about billet made me wonder if they redesigned the wheel to make it better then made it billet for kicks.
