Thoughts on potential speaker setup
Andy_Mac
Looking at getting a better setup for my legacy as it currently sounds like absolute rubbish.
Thinking maybe two 6x9\'s in the section behind rear seats. I\'ve heard good things about rockford fosgate and figured i\'d go with them for these speakers atleast. Just not sure whether to go for the punch series or prime. Anyone tried both as if the punch is not much better i\'d rather not spend the extra $$
Also i can\'t be bothered with a sub as space is limited as is in a sedan.
Thinking either of these
http://www.hyper.co.nz/drive/product/speakers/129/coax-6x9-inch-p1692-punch-series/153404/detail
http://www.hyper.co.nz/drive/product/speakers/129/coax-6x9-inch-r1693-prime-series/153427/detail
With
http://www.hyper.co.nz/drive/product/amps/131/amp-2-channel-pbr300x2-300-watt-rail-boost/153457/detail
For the amp
And the door speakers will get sorted after i make up my mind for this part
changed my mind from that, had a look in the boot and what i thought was a 2nd 6x9 hole was actually something much smaller, so going to stick with one 6x9 for now.
would these see much benefit from being hooked up to an amp
http://www.hyper.co.nz/drive/product/speakers/129/coax-6-5-inch-p165-punch-series/174736/detail
thinking maybe one of those in each door
 Timmah said:
If I was in your shoes, I\'d upgrade the front speakers to a good quality component set and buy a small sub for the bass. Run them off a 4ch amp with 2ch\'s bridged for the sub.
^This is a good idea
I would definatly spend some time on putting something decent into the front doors.(when you go to a concert most of the noise is coming from infront or beside you, not from the back)
I definatly wouldnt go with just 1 6x9. (what your really looking for is a good balance, having 1 would co*k that balance up)
You definatly want some bass from somewhere, a 10 or a 12inch sub wont take up too much room in the back.
Get a 4 channel amp, and as mentioned bridge 2 for the sub.(there are some rather good 4 chnls for really good prices, have a look around before you buy).
narrowed it down to this setup which i think wwill get the job done.
DD 8" sub
http://www.onlinecaraudio.co.nz/DD_LE_MINI08
Infinity components
http://www.onlinecaraudio.co.nz/Infinity_REF6510CS
and a amp capable of atleast 90w per channel. Narrowed it down to these two as a haven\'t found many others that\'ll do round the 90w mark
http://www.onlinecaraudio.co.nz/JBL_GTO1004
http://www.hyper.co.nz/drive/product/amps/131/amp-4-channel-lw4-640-lil-wonder/153786/detail
just can\'t decide whether the JBL is worth the $100 extra
I\'m sure if you say you\'re buying a bunch of stuff from Online Car Audio (Or Abtec as they are also known), if you say you\'re tossing up an amp, they will give you a deal on it to match that one, or give you options to match what you are buying.
Their trademe listings (same as their website prices I think though)
http://www.trademe.co.nz/Members/Listings.aspx?member=971524
They do have a set of ex-demo JBL components which will save you a bit of $
