Cams
Minaj
  • Replies 55
I told you bro cams aint just a easy cheap home job to do best to pull engine out an set cams up correctly with necceassary machining and make sure all clearances are checked. Well you do that you mozwel build the motor to match cams as your standard motor will find it a struggle to keep up with your high power demand 280kw plus cams will surely meet u past the 300kw. Cheaper in the long run to do together instead of running your factory motor itll be a ticking time bomb.
Mind you have heard good things about v7 engines bein reliable tho
