IAT relocation (standard MAF)
Kiwi_Fozze
hey guys, looking at moving my IAT sensor, or rather, disabling the sensor that\'s in the MAF and taking the sensor wires to a post i/c sensor (aftermarket, obviously)
at the same time, should i be looking to mount the sensor into the intercooler? or into the piping (after eventually going fmic maybe)? or into the inlet manifold?
any help would be most appreciated..
churr
If u check my build the iat (and where i usually see it) is on the pipe between fmic outlet and the throttle body. If you run tmic then directly in to core makes sense and as near the throttle body as you can on the cold side.
Good idea to have it post ic.
Into the manifold would be advised as it suffers heat soat more than the rest of the system
Into the manifold would\'nt be advised as it suffers heat soat more than the rest of the system
STi have one in the mani dont they as well? You could just fmic and mount maf in the intercooler to tb pipe like they do in \'merica.
Boon ran his where Jon said iirc check with him for results.
churr
know some ppl use the v8 sti mani as they have the iat sensor in the mani
or u can just custom mount in mani like subaru does..
if fmic then it will be a lot easier as can mount in the pipe
hmm isint ur sti quick enough already bro
 evowrx']
Into the manifold b]would\'nt[/b] be advised as it suffers heat soat more than the rest of the system
Do that :D
Heat soak is the DEVOL (you have to say it like billy madisons\' mum)
If you mount it in the manifold and don\'t run phenolic spacers it will be affected by heat soak from the manifold itself.
I put mine just to one side of the TB outlet in my TMIC. If you have a standard V7 TMIC you\'ll probably need to weld a boss on as the alloy mightn\'t take a thread too well.
excuse my naivety, but shouldn\'t a pre-MAF temp sensor stay before the turbo?
if the factory ECU is using the temp sensor for any kind of correction then the maps will be tuned to the temperature range seen pre-turbo eh?
unless of course you are playing with the tune or running aftermarket ECU?
People seem to do it. Playing with tune is whats happening here dude.
