2000 legacy twin turbo question
Blitzn
 Blitzn said:
Are these engines water cooled or oil cooled? Also is it true that u don\'t need a turbo timer for watercooled engines?
Cheers :)
Common misconception there
Subaru engines are oil cooled only, the water is purely used for the interior heater and to highlight blown headgaskets
They also run a continuous oil refreshment system, (via a slow leak out rocker covers and internal burn off past the piston rings) that ensures a constant top up of fresh oil. This means traditional servicing is not required, as the oil supply is replaced outright over a period of time rather than the inferior "all at once" method other manufacturers use
Novel thinking, ahead of its time in my view
