I'm seriously thinking about shaping out my mags for the factory 18" straight spoke wheels that come on the BP turbo Legacy.
Anyone done this? Any pics?
Am I going to be able to use the factory tyre size?
I also assume these will fit over factory 4 pot brakes?
Im going to assume the factory tire size for the BP wheels are 225 wide since thats whats on my car. If they are, you will need atleast a 5mm spacer in the rear, otherwise it will not clear the shock. A rear guard roll will be needed if you are lower than standard height. Even at standard height it probably wouldnt be a bad idea to roll them as it will most likely rub when you go over dips/bumps
The factory size is 215/40/18, so check the rolling diameter against 205/50/16 to see how far your speedo will be out. The width should be fine. Yes, they fit over four pots. You might need a guard roll in the rear.
Hrm, looks like 2.95℅ bigger, which is not major. Just keep in mind your speedo is reading low.
This is when I tried my spare BP set on the coupe - I think to check the four pot thing.
 gotasuby said:
Tyre size is 215/45r18
Woops, well that's more like 6.5%, which is a lot. I confused myself because we're now running 225/40/18s on the Legacy which has a much greater choice.
I've seen these rims driving around on a blue coupe in Wellington. Someone on here might've even bought that car (had Wilwoods and some other bits and pieces). You definitely don't want to use the factory tyres though.
 gotasuby said:
Guy at work has car with will woods on it with those wheels. I'll check tyre size.
Is it a wrx? Do you mind snapping a pic?
