Yeah was awhile ago now, just found it on my laptop so thought id share it. Car had a slight miss in top end of 2nd in that vid though. Dyno showed 280wkw at 6k.
  • 2 months later...
How would a car like this go against a car like the Mercedes E55 that has 350kw at the crank? Because the Mercedes is higher would it still win a 1/4 mile race? Or do other factors come into play
E55's engine was tuned to 476 PS (350 kW; 469 hp) and 700 N·m (520 lb·ft), the low end of the supercharged 55 range due to its longer exhaust system, compared to the SL55 AMG's engine at the high end which made 517 PS (380 kW; 510 hp) and 720 N·m (530 lb·ft).
A 300wkw Subaru is probably making the better part of 400kw at the crank.
Add AWD, subtract about 600kg and the Subaru would absolutely destroy it. Especially if it has a decent ECU with launch control.
