I've seen this mod covered a few times now, so thought I would document it as I go for hits and giggles. To fit 2 pot rear callipers to a BE/BH you'll need either S401 Legacy backing plates or some Kartboy adaptors:
Kartboy adapters:
http://www.rallysportdirect.com/Kartboy-KB-016-Big-Brake-Adapters-FHI-2-Pot-Rear-Subaru
Genuine S401 Legacy backing plates, P/N RH-2670466000 & LH-2670466010:
S401 style copies made by Flatt-Racing:
http://www.flatt-racing.com/
For some reason I've ended up with two sets of 2 pots, so painted the black set red for a colour comparison OEM red/VHT real red SP731 calliper paint:
Spent about an hour prepping each calliper, sanding with 180 grit wet and dry. Then using a small die bit in the dremel for the hard to reach spots. Then cleaned up with wax and grease remover, taped up ready for paint:
Two thin coats, then one final medium coat. Then oven baked for 1 hour at 93c to cure the paint (as per can instructions). Cooled down and masking tape removed, here's the colour difference:
All parts cleaned, polished and reassembled:
Then the finishing touch, high temp vinyl decals from ebay:
Link to ebay seller: http://www.ebay.com/itm/SUBARU-Brake-Caliper-Calliper-Stickers-Decals-Impreza-WRX-Sti-x-3-SMALL-REAR-/380756039797?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58a6d41875
Hopefully there's some fine weather this weekend and I can get them on and throw some more pics up.
Edited by Rosssub
ooh; a second set of 2- pots... ; I dont like that I promised myself I wouldn't mod the wrx 'til it's paid off haha!
Good to see the pic-heavy write-ups are back.
Love your detail bro!
There'll be more around when the time is right. Has been a while since I did one, but cheers man. :)
When every gram counts. The single pot sliders weigh 3.23kg each, the STI 2 pots are 1.84kg each:
Seized old single pot callipers coming off:
Calliper, rotor and handbrake assembly removed:
Bearing hub removed:
Now the original backing plate can come off:
New backing plate installed and bearing hub back on:
New 2 pot callipers on:
Before:
After:
 gotasuby said:
Got the part number for the backing plates? Well done btw.
Thanks. Nah sorry I don't. I thought I had found them in this thread:http://clubsub.org.nz/forum/showthread.php?44515-R160-2-pot-calliper-backing-plates-GreymouthBut they are for a GDA, maybe GC/GF.
Here's a pic of the new plates (top left), OEM BH (top right) and GDA/GC/GF 2 pot(bottom). Different size hub centre, park brake pad mounts and wheel speed sensor location:
 ADIKT said:
Ross do you want to sell the other set? My gf8 could really do with some.
Yeah man yours if you want them, the spare plates I've got should fit your wagon too.
Pm a price with the backing plates included. Cheers
 sobanoodle said:
Damn awesome as always!
Those are the ones I was meant to put on mine, right? Flatt racing dev. or something like that?
:) Yeah man, that's them.
 sobanoodle said:
Glad they ended up in good caring hands ;)
Have you noticed much difference performance-wise?
:) Definitely feels better, but hard to compare because my rears have been seized for a while now.
How easy was it to remove hub and bearing assembly? Run into any problems? This has given me a kick up the arse to finish my conversion. Cheers Ross.
No problems this time round, but I greased everything really well last time it was apart. The first time they came apart to do the wheel bearings I had major headache.
Even with this beast the axles wouldn't budge, outer splines completely seized into the hub:
Ended up having to remove the trailing arms/axles complete:
Then use a 20t press to remove the axles:
Thanks man, don't let me put you off though. That was worst case scenario. Maybe line up some heavy gear to use before you start, just in case.
You're doing a Brembo conversion aren't you? In the BH?
 STiNGR said:
Yer, got the front brembos on just gota dot the rear ones. Got v7 2pot backing plates I will use. Yup on the BH.
Nice. :) Do the version 7 backing plates look like the bottom ones in this pic?
That's what I think the bottom pictured plate is off. Which means they wont fit on a BH/BE. You should be able to tell with just the handbrake assembly off.
Here's the difference between the plates/hub sizes and bolt spacing, hub bearing is BE/BH:
I've got the 2pot brembo callipers already, I've got backing plates that come off a v7 wrx which ran the 2pot rear callipers. Are ya saying these backing plates won't work? I'm sure ive read places that this is what people do? Will be ripped if they no good.
This is what I have to play with anyways.
