What do I do? Oil cooler and water pump issues
slystiguy
If you're wanting to log oil temp, just buy and oil temp gauge and I'll sit passenger and make note of what's going on.
Also, workshopMgr is a perfect example of how you will be a okay! His son and himself weren't exactly going easy on the car at Manfield.. and Manfield isn't friendly towards Subaru's.
I can also agree with Loner.
if you're really really stuck, DacerX and myself will be more than happy to take you out to Richards and let him pop in a new water pump or whatever. Just sing out.
Interesting about the water cooling.
Subaru want frekin $21 ex japan for that oil cooling replacement nipple thing. Thinking I might just blank off the cooler and leave it on there? Any reason why I couldn't do this?
Edited by slystiguy
Been ringing around with no luck...
Where does one get rubber caps to suit heated radiator water? Is the factory part on the automatic plugged with a cap or simply replaced the metal nipple piece with a plug? Does anyone have the part number for the automatic plug setup?
Completely random though here... But the car in question is a bc5 first gen legacy. The old single turbo water to air intercooler one. What if I leave this oil cooler in place and run an external mini water radiator cooler which is connected to the now not running water to air circulation pump... It would automatically switch on when the engine was hot and boosting... Would it heat the smaller water volume to fast?
Thoughts?
