How much of the key broke off?
Can you see the end of the key when you push the dust flap aside?
We use dental picks for extracting broken keys, you have any lying around? ;D
Dont push the key further into the lock, it can only come out one way.
If worse comes to worse pull the lock out and send it up to me.
What area are you in ??? is normally a quick job for a locksmith ( I just happen to be one) pm me and let me know if i can help you out :)
Take the lock out of the car and bang it really hard on a piece of wood to shake the key out far enough to grab with the tweezers? Might have to jamb the tab open while you do it, perhaps a two handed operation on the edge of the kitchen table with one hand holding a pin to hold he tab open. Failing that take it apart or have it taken apart.
Guest Rugged_RS
i can see the pin slipping.... owch
You would be better off just taking the lock into a locksmith your in wellington right? Go to Master lockamiths and get them to do it be around 25 dollars be worth it save you the pain of giving yourself a nice stab in the hand hahahahahahahahaha
Guest Rugged_RS
gutted if your ambi-dexterious then
I can't believe no one has laughed at you.
hahahahahahahahahahahahahahhahahaha.
there.
Guest Rugged_RS
lol prob because no one else is as mean as you, or maybe not as honest? i dunno haha but now im laughing to .. ;D
there.
OUch, that hurt my feelings, i'm going to sit in a corner and cry now.
will wait till the next fine day, and take the lock of and into a locksmith.
 keltik said:
How do you break a key in a lock anyways? Generally they seem to bend a bit before snapping and no lock should be that tight
Some would say i went full retard, some would say unlucky.
I put key in, turned it, boot unlocked, key stub came out, important part of key remained in lock.
I suspect it was already cracked, and its not something ya look at when opening the car each day, i'm just kinda glad it didn't come out in the ignition :-[
Guest Rugged_RS
that wudnt be so bad, depending on how good your alarm was, all ud need to start it wud b a screw driver lol
 TURTLE']
there.
Impressed with your sensitivity. It shows a lot of courage.
Guest Rugged_RS
men dont get to have layers, hard shell on the outside, soft runny goo on the inside ;D
There some stuff from shellys call "knead it" its like a metal putty, when kneaded together with the inner compound it become hard as metal, you could use a wax to prevent the sticking to the key lock.
knead some together (soft) and use it to attach to the broken key bit once harden It may just pull out or pull out enough to get a pliers on to it..
(my 2 cents)
(my 2 cents)
Umm lets see I've only been a locksmith for about 12years and I would say that i have seen people try this before and it will all end in tears and more money wasted. Be smart and take it to a locksmith my 5bucks worth :)
Yeh will go to a locksmith, thats the easiest way methinks
I was however, thinking of jamming it open with a pin and then doing a few hard launches and hoping the inertia from the car will throw it out. Maybe in a school zone as i heard theres more grip there.
UMM yeah sounds sweet............................................Bahahahahahahahahahahaha prob more chance of giving yourself whiplash than getting the key out!!!!! And again could end up being expensive too :)
Got called out one day to remove a broken key from an ignition.
Got the broken piece out and some sellotape as well.
Seems that the petrol station attendent broke the key and thought it would be a
good idea to sellotape the 2 pieces together ::)
