Hi,
I have increasing problems with the clock/info unit in my BP9 legacy- Its the piece under the cubby between the centre vents. Sometimes it shows nothing at all (although the button for turning the dash lights to bright still works)- a bit of hard tapping and it will come back to life. Its happening more and more often so I took the unit apart just to check for a dry solder joint or dodgy capacitor etc- I couldn't see anything.
Is this a common problem/is there a good fix or is it just a case of a replacement unit?
Very common. To be honest though from reading other threads it doesn't sound like something many people have all that much luck fixing. May be better off just getting a replacemnet one, assume yours has the fuel economy and all that in the clock aswell?
Thanks for the replies, yea its the fuel economy etc too. Almost seems to me like its just the backlight- an obvious dry solder joint would be too easy!
Can that- a bit more googling reveals this:
See post 15
http://www.uklegacy.com/forums/index.php/topic/121140-03-trip-computerclock-problem/
I will take mine apart in the next day or two and check resistor R4
Edited by Colourfyre
God I went through like 4 of these things trying to sort the old man's BP Outback, I was getting faulty ones for free and reflowing half the damn board and they would only last a week.
In the end he bit the bullet and bought a new one from Subaru ($$$)
Presumably that mitsispec guy knows something I don't because the ones I played with looked primo after a bit of reflowing, even under a magnifying glass.
EDIT: Never re-did that R4 though
Double edit: Ugh, if you do get in there, don't just bend the legs of the display, de-solder them properly, you can see in that guys picture that he's cracked half the solder joints on it and it doesn't take a lot of wiggling to metal-fatigue those thin legs.
Edited by boon
Had the exact same problem with mine and got onto the same site that is posted above..
Took it to a local auto sparky and told him all I wanted done was 511 resoldered which cost me a grand total of 20 buckaroonies to do.
That was about 9 months ago and it's been all good since.
It may not work but it may save you a fair whack of money cause I would hate to think how much a Subaru replacement would set you back!
Good luck.
I remember this with my old BP Legacy. I done the oven trick and put it in oven to re melt the solder. Worked sweet for a couple of months then i done it again but left it in their to long and well it melted the board a bit. Their is a sweet spot in their somewhere haha
