WRX STI knocking shocks
So ever since iv owned my 01 STI the rear struts have had a knock when moving around carparks and going through gutters etc. Now all four are starting to knock, with the back being the worst. I plan on sending it in and getting them stripped and greased & serviced and getting grease nipples added for ease of maintenance in the future. I cant afford to put adjusties in or replace all the struts with new ones...however, i have thought about getting second hand struts and servicing them and chucking them in.
My knowledge on suspension is limited so any info would be choice. Curious to know what others have done, or if the method above has worked.
- - - i do have tein spings in at the moment... which may not be helping with the issue... i am tossing up to whether i should run factory springs again.. - - -
Have you checked your sway bar bushes? They might be dry and causing the knock. With my old wagon the rears became quite noisy, not really a knock and I narrowed it down to the sway bar bushes had become dry.
In saying that I did regrease the struts, it wasn't hard to do, the only hard part was I didn't' realise the bottom of the piston thing (I don't know the name of it) that bolts onto strut casing has a lock key that locks it in place with the strut casing or whatever its' called because it bolts fully down.
Richard does have a full set of STi struts on that shell next to his shed that he would probably sell at a sharp price too.
cheers, i didnt think of the sway bars. yea richard will be doing it all for me (im mechanically incapable and will break something) so he'll check everything and service anything that is in need of some attention. It all really depends if my struts are still in good nick when he pulls them all apart. Otherwise i may end up doing thats. Great info cheers man
Edited by hunter951
 Andy_Mac said:
Give that a go. 15 odd bucks for a tub of the correct grease and should be able to do all 4 on a WRX, Legacy's use a different style rear shock that Can't be pulled apart in the same way.
http://wrxinfo.com/how_tos/suspension/regreasestruts.htm
cheers for the link. Think id rather richard do it and add grease nipples at the same time haha
That's fair enough, I too and mechanically a cabbage! The Chch roads aren't the best on our suspension :(
Speaking of struts.. I've yet to get the struts out of the Version 8 wagon he's got at the paddock .. I paid for them a few months ago now :P
yea chch road suck balls. kinda why im think going back to factory springs maybe a good option. Car looks good on the teins though... performance has decreased but i dont track it
May be an idea to keep your eyes out for some STi Pink springs.. will drop the car a little lower than factory, but should still perform well.
I'll chuck in there that having got intimately familiar with the internals of an inverted coilover strut when rebuilding mine, if your struts are knocking then the bushings are shagged, period. You can pack the **** out of the lower with grease and that will hide the symptoms but with a macpherson strut suspension setup it will always be loose as a cock in a sock.
Im assuming you can replace the bushings?
