Spray painting some rims
funkytown
 jake_the_muss said:
how cheap do you want it to be? i had 4 rims professionally powdercoated for $60. $15 a corner seemed sweet as to me.
that is real cheap bro.. only thing is the rubber is on the rims and that seems like lots of farking round to get them off and then back on and rebalanced...
I have just going to tape off all the rubber so's not to mark that and do it myself..
Thanks for the other links etc guys
Lol balancing and remounting is only going to sting you maybe $40. Id get them powder coated and have a much more professional job thats going to last longer for not much more money.
Also ten times easier for you lol
 nzkaosnz said:
TRAITOR!
i hearby demand that you remove the title of " Semi-Elite Master of "doing it on the cheap" " from your profile.
if you going black, one coat of black etch primer works wonders.
going white dude.. in the first post.. its going over on wheels the same as keltiks, late model gtb rims
 nzkaosnz said:
TRAITOR!
i did say "semi" elite....
Those wheels will certainly look interesting in white
so i had a crack last weekend at painting the rims. 2 coats of white later and they were starting to look of for a home job, ive been out to touch them up now and then start applying the clear but they hvae gone mental, anything aplied to the wheels is just causing the applied paint to all just peel up and look totally shit.. :(
WHY?
looks like im gng to have to sand the WHOLE lot off and start again..
Guest Fastfour
You've got some residue of something on the rims which is causing the paint to do that. Make sure they are super clean. Use something like Mineral turpentine to clean them up.
you could acid dip them that'd be alot quicker. also make sure you prep them right by cleaning them with prepsol or something. Definately use primer if your painting, probably recomend using an etching primer as your painting to bare metal.
GASKET STRIPPER works a treat for removing paint(from everything so be careful)
give them a good waterblast after,then clean with solvent,then sand(even use a brillo pad they prettty good) then use a alloy primer then your top coat :)
