https://jdmfsm.info/Auto/Japan/Subaru/Impreza/2008/Impreza WRX STI 2008/
using the diagrams above I've checked the fuses and the relays swapped around that I can find.
the AC panel is still dead. this makes the fan, AC and rear defogger all useless.
nothing else is having issues, i.e. Dash and clock panel that share fuses are all ok. Doors etc still lock that shares the BCM.
the panel died when the AC pump clutch was rubbing and I pulled the relays in the engine bay looking for the burning smell. The car wasn't running at the time. Had to cut the belt to stop the AC clutch rubbing in the end.
the panel was working up until then.
so either I have 2 dead relays in the engine bay
the panel has failed
the BCM unit has failed only to the AC area.
Any ideas?
So i assume you’ve tested the plug on the back of the unit so ensure there is 12volt across all pins that should have so based on those diagrams?
No that's next to test every 12v and ground.
Didnt have a meter with me today.
ahvent found the fan motor relay yet either but that's unlikely to be the issue.
Edited by Gripless
  • 2 months later...
Well I finally got a chance to look at this
seems fuse 22 and the aircon panel pins are getting 3v not 12v. Only thing it passes through unique seems to be a push button start relay #2. The rest of the circuit is working as the mat feeds start relay #1 and since the car runs that has to be ok.
Time to find a replacement starter relay.
  • 8 months later...
so I finally got a new battery which died before Xmas.
checked fuses.
Even swapped some around or replaced for good measure.
even swapped the relay IG2 (and IG1) out but where is the accessory relay...
http://jdmfsm.info/Auto/Japan/Subaru/Impreza/2008/Impreza WRX STI 2008/contents/data/pdf/wi-18780e.pdf
this has it in B426 which is where?
and it appears to be big older style one from the pin out at the bottom of the page.
there are 5 matching relays on B425 next to the drivers fuse panel. IG1 and IG2 plus three others I have no names for.
PS B386 for the blower is in the passengers foot well dead center below and behind glovebox.
? so no relay there at all
left edge relay panel is only thing I haven’t got relays to swap out.
still have blower fan ones as well.
but that wouldn’t stop the rear deficit and act as well.
  • 5 months later...
    574.7k
