Share your knowledge!!!
  • Replies 96
nah boost gauge is correct ive tried 2 types.. it seems to be boosting algood. yeah free boost on 13-14 psi? weird huh
armstrong subaru did the rebuild i met a suby wrecker lastnight said few of his clients that had rebuilds from them also had boost problems FUJNNy enough they had blocked up pipes and stuff to reduce boost to save their rebuild warranties!!!!!!!
 F4TB01 said:
ok guys here we go lol
i pulled that vacume hose thing off the internal wastegate now every gears sits at 13-14 psi!!
weird huh so should i just leave it off?
so you have nothing hooked up to the internal gate now?
your boost problem maybe caused my the factory (provided that's what you use) controller, it may have been hooked up wrong, leak or set via the ECU to run a certain pressure
but holding steady in each gear doesn't sound like free boosting, normally it will keep boosting till it hit a cut of some sort
Yea well if the waste gate hose is off its free boosting, but its if not cutting then yeh id check out the turbo/up & down pipes/BOV leaks/boost leaks
if u boosting to 13-14 all the way and no spikes and u have no hose in the wastegate then its not normal bro..
with no hose in the wg as the revs rise u should see more and more boose like 19+ and then it should cut out..
if u only reaching 14 then its defenatly getting strangled.. check all the exhaust etc for blocks..
as for downpipe, teh bell mouthe brings boost faster as its got the highest outlet flow.. they have the wg seperator and its recesses up to the wy hole (needs accurate design) and that is the best of both worlds as allows top rpm flow once wg is open..
the simese flows well once the wg is open but a good open bellmouth collector with recessed wg split is best
sweet bro funny enough on the weekdn i had aboost cut on the motory way in 3rd gear? lol
so i but the hose back on for now just incase!! ill get somne one to check it out
