Share your knowledge!!!
Hey guys!!
i just got me a new v5 sti wagon!! .. cars algood box & clutch are tight!!
runs a vf28 when i put the pedal to the metal it just isnt pulling the way a sti should like from 3 - 6 thousand revs feels like its taking ages to get their just missing the OOMPH!! like its struggling?..but not hard to explain!! haha
im in Wellington and keen to take someone in the know for a lil blat in it to see what they think
- i considered new turbo?.. or a 2.5 down pipe that might givwe me that lil extra pull i know its capable of. but who knows!!
so who's keen for a blat lol!! im in the CBD area!!
  • Replies 96
some thoughts:
what boost are u running - put a proper meter on it to begin with.
also, what fuel?
any mods to the car?
reset the ecu and try again (on a cold nite) and see if feels any better
do a oil service and make sure there are no holes/leaks in the intake etc.
also, go to your local club dyno day - usually 80 buks and see what the car does and the AF ratio etc..
e.g. a makes RS was running slow and on the last dyno day it was showing really lean - turns out, someone had put a podin the intake but had a hole in the intake rubber behind the AFM - anyway, after plugging it and ecu reset, the car immediatly pulled almost 15-20 more kw ...
point is, it shouldnt feel slow and the vf28 is not laggy as others so should be more crisp etc..
a 25inch downpipe will do lots of difference.. i wud hazzarrd a guess at say 15kw or so difference
 F4TB01 said:
Hey guys!!
Send me a PM if your keen to have your car fixed properly
sweet thanks guys ill check the stuff you mentioned pappu!! - hey bro long time no see im the guy that swooped the 3'' v7 exhaust from you earlier this year lol - living in welly now!! hope all is good!
i have also Pm'd you Ichi ban
hey bro.. yea i thought so.. hope u get ur car sorted bro.. but yea its got to be something simple (hoping for ur wallet lol)...
could be many a thing have you got any codes on the computer ???
3-6 is when the turbo should be boosting so have you got a gauge to see how much your boosting.
Also my car ran sluggish when there was a slight leak on my bov as i had gc8 bov on a GDA tmic and they don't fit.
so i went for a drive in it today with him, it feels like its only running about 6-8psi.. its just not pulling.
So i would either guess its in limp mode - and ecu needs reset (why did it go limp to start with).. i dunno
Or its only running wastegate pressure for some reason - i didnt check the plumbing as i thought of it after i left.
I suggested
1) reset the ecu
2) get a boost gauge to tell what psi hes running
3) oh yer.. haha the FMIC piping.. its solid steal piping.. like heavy as **** stuff, and it has this massive sharp bend off the turbo wrapping back towards the intake - it cant be good for it. Would the sharp bend or the solid steal piping make and difference? it was 2.5" in diameter at a guess.
By the sounds of it time to check the basic's
Codes ?
Turbo wastegate setting and plumbing
engine condition ? inc worn crank keyway :)
Easiest way to check condition of engine is Vac reading at idle
 DPI said:
Sounds like LAGGGGGGGGGG...
Bin the front mount... :P
you needa see it to beelive it.. its solid metal tube pipe..?!
it does seem like basics rick, engine just been rebuilt 2000kms ago, no boost gauge - so yer, need to check what its running at idle and on boost - my bets is its only pulling 6-8 psi on boost, it just doesnt feel like anythings there,
ok peeps ill check all the stuff you said starting with boost gauge and reset ecu.. dont mock my piping haha its the new style for 5 second wagons haha
ill let you guys know how things go!! might see yous al the thursday meet up :)
stick up a photo of the turbo end of the piping, so they can see the bend, its pretty radical and i havent seen anything that sharp before..
