Hey guys probably a rookie mistake on my part
But while changing the fuel pump on my V11 Sti some sand that was around the fuel pump area fell into the fuel tank and I can now see it settled at the bottom of the tank
It's not a lot maybe 2 pinches of salt amount
Should I be worried about it? I have put in a new filter at the same time and car runs fine
I've got no experiance but i;d go with "she'll be rite mate'
if it ever picks up I bet the sock will do its job, then when you turn off, drops it etc
if you're really worried I'd check the fuel filter in the engine bay in a couple months maybe
Cheers that was my thinking too - Ill check the filter in a month or 2 in the engine bay
3 hours ago, TNHSTI said:
this filter is
On the Subaru''s I've dared lift bonnet I thought was the coke can canister Passenger side (about 2/3rds as tall?
EDIT LMGTFY :P
Ah yeah Mine don't have one of them that I can see - @Andy_Mac do you know if the V11 Sti's have a fuel filter in the engine bay anywhere?
  • Haha 1
Nah GR/GV’s and BL/BP Legacy’s use the same cradle which has the pre pump screen on the bottom of the pump and then a cardboard filter which is part of the top half of the fuel pump cradle.
  • Thanks 1
