Hi all,
Thinking about adding a digital dash to my ST BH. All the dashes I've found mainly require a can connection to work. I believe I have a link G3 V7 plug in ECU running the show and it has an empty 5 pin plug on the board which I believe can be used as the CAN port. Anyone able to confirm this?
Also if anyone has any recommendations on a digital dash would be appreciated. Currently looking into a Powertune digital one
Is the goal to replace the factory cluster? If so you’re a bit more limited in what will do all the factory stuff like indicators and odo and whatnot
Emtron do a real nice 10inch one, it’s only like 9 grand
Costs more than the car ? the idea was for a complete cluster replacement. I think lights and all that can be wired in to work for the dash
Yea i’d looked into powertune too but had never seen anyone doing odo which i assume is legally needed. Looks like a heap of work to get everything running as you want based on some of the questions rhat pop up on the powertune fb group. What about Haltech? The ic-7 is pretty reasonably priced and would possibly be better suited, or even the aim street dash that gives indicators amd engine light stuff on the side of the frame rather than just on the display
    574.7k
