Have you seen how on the later cars they have both fed from the same reservoir? Haven't seen it myself but it gets talked about a lot on FB pages.
Could get lucky and find that res fits straight on our brake master then just run the line down to the clutch however they do it from factory.
I had thought about that but didn’t like the idea much.
The risk of a clutch system leak drain brake fluid doesn’t sound good. I’ve had clutch slave cylinder fail as well as a pinhole in a clutch line before.
Plus using motul 660 as clutch fluid seems excessive.
    574.3k
