Cant see how pads to fit a BC2 will fit a BG5...something isnt right there. For that kind of money id just buy some bendix ultimates.
only ultimates i saw were for $195 or could that be for 4pots
Ive never compared them but it could well be right?
earlier bd/bg had smaller brakes than 294mm on later bd/bg so could be the same as bc5
you need to ask what compound they are... I can't figure it out from that auction.
I used Formula Ferodo pads with slotted rotors and lucas fluid and i couldnt get them to fade. Ultimates get a bit slippery after 4 laps.
using the Znoelli S12 slotted rotors, with matched scp550 (from znoelli) pads all round and the rbf550 fluid - didnt run out of brakes once - not the slightest amount of fade.
Looking at brakes last night tho i suspect the pads are getting down already. From when i went out in jases car, it felt by the "seat o meter"i had as much braking as the brembo's... thats imho
Those ones are NA-S compound, here is the description on them:
"Type NA-S is a sports pad, which is applicable to a wide range of rotor temperatures, from as low as 70°C to a high-speed running temperature of 450°C. Out in the street, this "almighty" pad delivers the necessary response at the important starting period. At the same time, it maintains low noise level, and comes in a broad line-up to match the driving needs of everyone, from the first-timer to the top notch driver"
So it would be more a street type pad rather than an all out track one. Would still be okay for a few laps I would say.
cheers guys, was just thinking when i need 2 get new pads, what 2 get, ive done 40.000ks on them and were in the car when got it, no idea what they are
 Tony']
That's what I thought, but was unable to find anything about them on the endless site. probably should have looked harder.
 loren']
yeah I dont think they do them anymore - all these new compounds are coming out now. I found that info on some american site.
Most likely old stock that they are trying to get rid off hence the price???
 Tony']
yeah, probably a pretty good deal. they sound like a good street pad.
Guest itsgotgo
got these in my forester,were in when first brought the car.
They are good for a bit of hard driving but for continuous hard braking and prolonged not so great.
could say a medium type pad,and minimal brake dust with long wearing :)
