YAY XMAS PRESSIE ARRIVED!!!
Woohoo my xmas pressie from my wife turned up today, a pair of v2 rex heads (thank you hunny).
Ive got them ready to install, port/ polished them today, wish I had the tools to port-match but that can wait another day.
I got some great step by step photos too so as soon as i figure out how to upload the bloody things I will ;)
Also have to figure out a way to bolt on the new injector rails, Ive got a set of red-top 750cc side-feeds to go in but the only rails i could find (with minimal modification) were from a 92 leggy that had almost identical injectors, bar flow-matching.
Well i hope hope the next stage flows smoothly too...
 wildturkey']
[quote name='DRFVDR said:
nice score.......I'm in Lower Hutt myself.........can catch up if u got time
Yeah I will so let u know as I may need a hand with the loading :) I have a trailer but no ramps so will need to find a suitable loading area :) Pm me your contact details :)
 zarnah said:
is there even any difference between v2 wrx and early rs/gt heads??
yea theres a BIG difference... let meh explain;
89-92 EJ20 heads have lateral lines on the top and bottom of the valve cover,
21060_1298580314669_1535234429_763695_56
and use mechanical "tappets". (which in turn end up a problem through wear and you end up with my problem - noisey tappets)
93-97 EJ20 heads have only lateral lines at the top of the valve cover,
21060_1298567154340_1535234429_763661_90
these use a solid lifter (bucket) as opposed to the tappet.
Finally all other heads there on out are pretty much identical the change between tappet and bucket is pretty much it...
Anyhoo back to my xmas pressie, behold!!
21060_1298566234317_1535234429_763638_60
internally was fairly grubby but thats what you get when buying second hand heads...
21060_1298566394321_1535234429_763642_6221060_1298566474323_1535234429_763644_3221060_1298566434322_1535234429_763643_33
but nothing a good ol fashioned port an polish wont fix,
21060_1298566514324_1535234429_763645_3521060_1298566554325_1535234429_763646_1021060_1298566594326_1535234429_763647_11
taadaa!!!
21060_1298567274343_1535234429_763664_77
