  • Upcoming Events
    No upcoming events found
  1. General
    1. General Vehicle Discussion
      General discussion board for anything car related
      103.1k
      posts
    2. Stolen Vehicle Register
      If your missing something or have information about things lost
      4.9k
      posts
  2. Knowledge Base
    1. General FAQ (Read Only)
      Non-model specific frequently asked questions relating to Subarus. (Read Only)
      If you have something to add, contact one of the Mod team (Full List HERE)
      43
      posts
    2. 80.1k
      posts
    3. 87.7k
      posts
    4. Legal
      All things regulatory, WOFs, Standards etc
      2.9k
      posts
    5. Motorsports
      Track day and MSNZ specific discussion
      1.8k
      posts
    6. "Other" Tech Questions
      discuss anything non Subaru related, your tools or how to fix a Lawnmower in here
      649
      posts
    7. Product and service reviews
      Share your first hand experiences good or bad.
      339
      posts
  3. Regions/Events
    1. ClubSUB Events
      Only things we're involved with such as Flat-Nats
      9k
      posts
    2. Auckland/Northland
      General discussion board for all our Auckland/Northland members
      Moderator : ADIKT:
      17.9k
      posts
    3. Waikato / Bay of Plenty / Taupo
      General discussion board for all our members in the Waikato, Bay of Plenty, King Country, Taupo.
      Moderator : nztintin
      2.1k
      posts
    4. Taranaki / Whanganui
      General discussion board for the Taranaki and Whanganui areas
      25
      posts
    5. Manawatu / Wairarapa / Hawkes Bay
      This team represents the East Coast, Hawke's Bay, Manawatu, Poverty Bay, Wairarapa-Bush areas
      5.4k
      posts
    6. Wellington / Kapiti
      General discussion board for all of our Wellington and Kapiti based members.
      Moderators : Chulozumo & Sc00byd00
      10.5k
      posts
    7. Nelson Bays/Marlborough
      Topics relating to Nelson Bays/Marlborough
      Moderator: VACANT : apply within
      76
      posts
    8. Canterbury
      From Timaru to Kaikoura, the Port Hills to Mt Cook, Its all Red and Black here!
      11.7k
      posts
    9. Otago / Southland
      General discussion for all our Otago / Southland based members.
      Moderator : Tydon
      7k
      posts
    10. Outside NZ
      Post & share your international events & see who's active in your Neck of the woods
      18
      posts
  4. Classifieds
    1. Car Exchange
      Buy / Sell / Trade vehicles
      post
    2. Parts Exchange
      Buy / Sell / Trade car parts
      post
  5. ClubSUB Shop
    1. ClubSUB Shop
      The place to go for Subscription purchases/renewals, stickers, banners, t-shirts and anything else we can get our logo on.
      posts
  • Member Statistics
    8,633
    Total Members
    1,713
    Most Online
    IgnobleSTI
    Newest Member
    IgnobleSTI
  • Who's Online   1 Member, 0 Anonymous, 741 Guests (See full list)
    • I found this https://xcceleration.com/pinouts/Subaru pinouts/ECU Pinouts BC5 BG5a WRX (4 plug) - Single Swap.pdf and looks like adding wires for TPMs and it’s ground is needed. Possible the pins or wire is damaged or a joint cracked that won’t show up when the car isn’t moving.   I was thinking alternatively you may not have an electrical issue. Maybe you have a split in a vacuum or boost line that opens up and stuffs up the idle.You could get the same with worn spark leads when they get hot. Anything that drops revs outside where the ecu target is and throws an error. So a leak when the ecu is trying to idle down would throw an error for idle control as that’s what it is doing. It can’t predict air leaks.   Have you checked and replaced the throttle butterfly closes fully?   I’d also remove the ecu case and check the capacitors for leaks.
    • Yup, was thinking similar - this Bc5 was originally Auto - the Ecu is from a Manual WRX Ver1 (Z4 ECU) The Idle switch is built into the TPS and is functioning fine and not throwing a code (it did throw a idle switch code until i adjusted the TPS with a multimeter to spec volages with the car on, that fixed the idle switch code)   I got right under the dash with flashlight to have a look and there is no corresponding plug that the blue plug on the accelerator pedal to plug into - really scratching my head on this one    Im guessing the ECU does have an input for the Accelerator Pedal Switch, otherwise it wouldnt know to throw the code for it   Bit odd though because I owned and drove the car for ages without it throwing a code for the Accelerator Pedal Switch    As for Vacuum lines - what vacuum lines are you referring to?    Z4 ECU Wiring Diagram doesnt show any additional input for any unknown sensor except (Self Shutoff Control)    Let me know if you spot anything
    • Well it could be: for the automatic ecu, just on the body loom. used as alternative for idle switch  a brake switch Are there any wires in your ecu that should be unpopulated compared to the diagram? That may not be an exact match. Look for ones that match that plugs colours first. Have you checked and replaced any of those small vacuum lines?
    • Just remember your car is likely only 175wkw now so 210wkw is a noticeable gain. My manual 2L was only 185wkw stock tuned with rebuild engine. Most coolers work fine but, Ive always used the tube and fin single pass type coolers. like this https://www.aliexpress.com/item/1005006803498379.html Just find a size big enough that you can P clamp to the lower rad support and maybe the center or side supports. They are low density fins so don’t block much flow so more air goes through them rather than around. Plus they have the lowest restriction to flow for the gearbox pump. The pipes are reasonably thick so don’t get hole as often from stones or rubbish hitting them. I always put in sideways with inlet at the bottom and the out at top so the bubbles bleed out upwards and nothing gets caught in the loops.  Just remember a cheap set of 17” wheels and secondhand semislicks will likely make more difference on track than those power upgrades. I always get motul 660 brake fluid as late braking can push temps very high with smaller brakes.
    • Okay - Im on the right track now I got another Tested TPS and still threw the same 43 Fault Code after clearing So I did abit of investigation based on the fault being Accelerator Pedal Switch   I found the switch - on the accelerator pedal - a small switch on top of the pedal AND.............   its unplugged ------ omfg +_ +   Anyway there is no where for it to plug into   I have the ECU pin outs and there is no wire for Accelerator Pedal Switch and I cant find any wiring diagram showing where it goes -_ -!   Any gurus out there got any ideas?   Pic attached
  • Latest Products
  • Popular Contributors
    • Total Topics
    • Total Posts
