• August 01, 2010, 05:46:24 pm *
  • Welcome, Guest
Please login or register.
Login with username, password and session length
Pages: [1] 2
Author Topic: Cheapest Place to get Springs Fitted  (Read 324 times)
0 Members and 1 Guest are viewing this topic.
Flat4
  • CHCH Member
  • Forum Member
  • Offline Offline
    • View Profile
« on: February 23, 2010, 05:10:33 pm »
I'm planning on buying second hand lowering springs, so I'm looking for the best (cheapest) place to go to get them fitted (with wheel alignment) in Chch.
So far Mag and Turbo have given me the best price, although it's still more than I was hoping to spend.
Any suggestions?
Logged
smurff
  • Club Captain
  • Forum Member
  • Online Online
    • View Profile
Re: Cheapest Place to get Springs Fitted
« Reply #1 on: February 23, 2010, 05:23:12 pm »
in your own garage for the springs. . . how ever long it takes you and the beers you drink
then get the wheel alighnment after
-smurff
Logged
1998 legacy GTB parrallel TT
2002 holden commie ute
Flat4
  • CHCH Member
  • Forum Member
  • Offline Offline
    • View Profile
« Reply #2 on: February 23, 2010, 06:06:57 pm »
Yeah I thought it would be better to leave it to someone who knows what they're doing... haha. I don't have a spring compressor or torque wrench either
Logged
smurff
  • Club Captain
  • Forum Member
  • Online Online
    • View Profile
« Reply #3 on: February 23, 2010, 06:21:19 pm »
spring compressors are $40 from ripco, and you dont need a torque wrench :P
i can tell you now, mag and turbo wont use a torque wrench.
-smurff
Logged
Drunkenmonkey
  • Paid Member
  • Forum Member
  • Offline Offline
  • MMMM 6 POT
    • View Profile
« Reply #4 on: February 23, 2010, 06:30:28 pm »
need a power bar comes in most 1/2" socket sets, someone in chch will know what to do
Logged
'please use clubsub responsibly, use only as directed, if you feel ill or get a rash, plea
smurff
  • Club Captain
  • Forum Member
  • Online Online
    • View Profile
« Reply #5 on: February 23, 2010, 06:34:39 pm »
in chch, they will have them cut and held in with cable ties in about an hour, no need for new springs,
only have to jack it up and take the wheel off to get the grinder in there :P
-smurff
Logged
Flat4
  • CHCH Member
  • Forum Member
  • Offline Offline
    • View Profile
« Reply #6 on: February 23, 2010, 06:52:17 pm »
Just realised I don't have any jack stands either (thought dad had some), so it will probably be easier and not much more expensive to pay someone else to do it.
Would it be easier to fit struts with the springs already on them?
I'm looking at buying Drunkenmonkey's KYB shocks and lowering springs for my leggy but being at uni this year I'm trying to be a bit more careful with my $$$ haha
Logged
funkytown
  • Paid Member
  • Forum Member
  • Offline Offline
    • View Profile
« Reply #7 on: February 23, 2010, 06:55:45 pm »
if your trying to be careful with $$ then do it yourself - yup fitting complete set is easier - you dont need axle stands if you just jack it up
Logged
04
smurff
  • Club Captain
  • Forum Member
  • Online Online
    • View Profile
« Reply #8 on: February 23, 2010, 06:57:03 pm »
well it would be easyier, no having to remove the spring from the strut.
just 5ish bolts on each corner and your done.
if you did this, buy the jack stands and do it yourself, or go to your local mechanic
-smurff
Logged
Drunkenmonkey
  • Paid Member
  • Forum Member
  • Offline Offline
  • MMMM 6 POT
    • View Profile
« Reply #9 on: February 23, 2010, 06:59:19 pm »
rather easy 5 bolts and they pop out
Logged
boostcut
  • Central North Island Member
  • Forum Member
  • Offline Offline
  • Clint is under his mums thumb *insert banjo song*
    • View Profile
« Reply #10 on: February 23, 2010, 07:03:23 pm »
just use some blocks instead of axle stands... if your fitting lowered springs yopu will need to lever the lower arm up into place to line up with the strut and could fall on you head. :-\
Logged
i think 4wd burnouts are pretty much the coolest burnouts. imagine if you had those colourful burning tires? a different colour on each wheel. it would be like a f***ing tropical smoothie tornado
smurff
  • Club Captain
  • Forum Member
  • Online Online
    • View Profile
« Reply #11 on: February 23, 2010, 07:04:21 pm »
+1
-smurff
Logged
dubbedup
  • Otago/Southland Member
  • Forum Member
  • Offline Offline
    • View Profile
« Reply #12 on: February 23, 2010, 07:05:44 pm »
and a brake line clip......
really easy thing to do, and would recommend the job to a novice.
Logged
smurff
  • Club Captain
  • Forum Member
  • Online Online
    • View Profile
« Reply #13 on: February 23, 2010, 07:09:28 pm »
ahhh very good thinking, twist them 90degs, and the slide out. IIRC
-smurff
Logged
CUDDAS
  • Paid Member
  • Forum Member
  • Offline Offline
    • View Profile
« Reply #14 on: February 23, 2010, 07:28:13 pm »
Well i have acess to several hoist's & have a vast selection of tools (air also spring compressor, shock tester ect) & including very expensive wheel alignment system & am a qualified wheel alignment technician, only an hour away down south in Ashburton.  :)
I may be able to help??
Logged
Pages: [1] 2
