Firenza
  • Content count
    1,071
33 Positive
2 Followers
About Firenza
  • Rank
    Forum Member
  • Birthday 09/11/86
    North Shore
367 profile views
  1. Yep, should be. Always wanted to visit the South island, so this is a good excuse
  2. Cheers, It doesn't look too bad for 250km. Although on the way to the locations I realised my front wheel bearings going Just in time for flat nats!
  3. Looks a bit more run down since you were there. Someone ram-raided the gates! Sensation Yachts - Selwood Road, Henderson new one
  4. I think this is based on a few factors. The first is the kind of Subarus we get in NZ. During the import boom of the 90s we mostly got Turbos like the BG5 GT and EJ25s like the 250t and Grand Wagon/Outback. For the average joe these mostly ended up being unreliable, the turbo motors were pretty highly strung and in need of good fuel and proper servicing, however most people used them as daily drivers, with a majority not treating them as they needed to. I've seen many a GT-b ruined with 91 octane fuel and shitty oil because "its just a Legacy wagon" (not considering that its a Twin Turbo wagon with about 280bhp!!) On the flip side, a lot got modded poorly with not a lot of thought given to longevity causing faults that stouter engines could survive. The ej2.5 motors again suffered with poor care, but also were very prone to Head Gasket issues. Unfortunately, that engine was very common in Japan, and so a lot ended up here after a few years, just in time for them to go pop. Kiwis tend to be pretty rough on their cars. Given the ease of getting a fresh import cheap from Japan, once a car hits a certain age and mileage people stop mostly caring, but once a trend emerges people jump on it and come to the conclusion that "Subarus are unreliable" without thought as to why that might be.
  5. Out of those two the Legacy has much more room, and has a flat floor and no lip like the Impreza, however if you want space you should go for a 3rd gen Legacy. Thats when they went to the multi link rear end, and as such they dont have the strut towers encroaching on the trunk space. My mates got a BC2 which is the 1.8 fwd and it has enough power to commute him to work and back, but its not fast. If you're loading it up with heavy S*** you might want to stick with 2litres and up. The Brighton 220s were alright, with the sohc 2.2 motor, but with 1st gen Legacies they arent as common any more so its a case of taking what you can get!
  6. If theyre glued on then you could try heating them up and trying to pry the front off, but your not easily going to get a replacement without buying a new set of those lights as the OE ones are different, and if your going to buy new ones then you may as well just fit those.
  7. They're Technocast Corsias, and I too really want a set, but so far havent found any in my size
  8. well easiest would be to connect them up to a connector you know works and push the button, otherwise if your feeling brave, they only have two pins - Earth and 12v. You figure out which is which and hook them up directly to a battery! But get it wrong and you could ruin the pump.
  9. Nah, should be pretty easy. I havent done one on the BG, but I have a BF and a Impreza and they're both the same. The rear hose is clipped to the left hand side of the reservior, and if you unclip it you usually have enough room to tilt it back so washer fluid wont run out the pumps when you remove the hoses. If the pumps are unknown its probably worth testing them before you go to the trouble of installing the whole thing too
  10. You can try removing the pump and running power to it. If it stays silent then its done its time. Also try swapping the connectors between the front are rear motors and then test the switch. If you pull it and still nothing happens then I could be the switch. A new one would probably be fairly expensive. When mine died I took it with me to pick a part, and get a replacement off the nicest newest looking car I could find. Theyre like $10 so grab a couple. You arent limited to BG Legacies either, you should be able to get them off newer Subarus too IIRC
  11. New rotors, and new pads! Turns out the ones I took off were OEM Subaru, so god knows how old they were! So far so good, i can stop now, unlike my track day cooked old ones
  12. I got all of those ones off trademe, just buying them then they appear. There's a few guys who refurbish wheels and then sell them on for a hobby, and they come up with some gems everyone and again
  13. Which one do you have?
  14. You on about that light on the boot? Depending on what market your car was made for, it could be a reverse light of a rear fog light. Light wise for the brake light, easiest is to go to repco, take the bulb out and show them. They will have it, however NZ doesnt really use the kind of numbers you have as theyre Syvania numbers, which are big in the US, but not here. If you want to find it yourself, then use this http://www.narva.com.au/products/globechart Narva is the main brand that Repco and SCA sell, and are generally the numbers that NZ uses. If you find the globe iusing that matrix, add the suffix BL on the end and you get the part number of an bulb hanging on the shelf in a blister pack.
  15. Going off the number it comes back to a Front LH shock for a GG9 Impreza, so seemingly not STI, It does have a note of 20N and 20K which were the names of the sporty wagons when the 2nd gen Impreza just came out, so maybe kinda the same as a WRX, but they dont directly cross to what a WRX had
  • Who's Online   0 Members, 0 Anonymous, 8 Guests (See full list)
