hey well my 95 gt legacy normally runs 8 psi boost and i was in town the other night and i was getting up and around 15 psi any ideas what is causing it?
everything is stock apart from the bov.
8 psi is only wastegate pressure, should be more up around 12-15 normally tho especailly on a cold night. If you are worried about it id check the hoses for vac leaks, could also be the boost control solenoid having a fit.
cheers i think its the fact it was a pretty coldish night. it seemed to handle 15 psi pretty good no lag or anything. just dont wanna push the engine to hard.
#10 runs from the primary down past the battery and dissapears into the front passenger guard. It has a plastic male-male joiner just before it goes in the guard. check that.
Tho i'm thinking possibly black box of doom.
i had a similar problem in my twin turbo rs (1994). it started boosting up to 19psi and ran fine. about 3000km later i blew a piston. running too lean i think. my new engines out of a 95 gt and this will cut out when the boost reaches 15psi which is sorta annoying. i might check my hoses too. let us know if you find whats wrong with yours
    574.6k
