sti ver6 boost
G-unit
  • Replies 106
 G-unit']
just checkd and the 1 on bottom goes into the intake pipe and blue hose going 2 turbo etc
[quote name='gazzy2000 said:
the one on the bottom of teh noid goes to the Turbo 'T" joiner (with pill etc) the one on the side of the noid (on a right angle) goes to inlet hose (the bleed off)
then its backwards by the sounds of it.
 funkytown']
yur, swap those fukers ;D be good if that fixes it, let us know!
 G-unit said:
well i abit more boost, 0.6bar now was 0.5bar, code 32 is 02 sensor, would that put it in limp mode?
na, dont think 02 wud put you in limp mode, you can just unplug it for now, it will run slighty rich.
WUd rather have it unplugged and slightly rich that having it plugged in and giving a real false reading..
 G-unit said:
would a buggered knock sensor cuase low psi? found where they are placed under the timc so ill replace it when i fit the sti tmic im getting
IIRC teh code for knock sensors only shows up if the sensor is stuffed, not if the signal is screwy.
Regarless of that..... The knock sensor is a protective device/sensor of which the ECU relies heaily on to detect det, so the ECU cud put you in safe mode to protect itself if the it thinks/knows the sensor is faulty, which wud make sense
 G-unit said:
so i cant just replace it myself?
no only mate with sti will be down on saturday, his a ver4 sti, the same sensor?
i wud hazzard a guess and say yes they are the same.
yea man just replace yrself easy as, just remember the angle the knock sensor is facing before u remove it and fit the other one the same... and it is 24NM...i just checked :)
from one of my other posts regarding torque settings for it:
Although the knock sensor is tuned* to pick up the vibrations caused by knock, typically around 4KHz, it is possible for a knock sensor to 'hear' other signals which the ECU interprets as knock.
Things that are loose, rattling or impacting together can confuse a knock sensor.
As the ignition advance map is adaptive, it is possible for the ECU to learn an incorrect mapping if the knock sensor is hearing things.
*The sensor may be tuned by torquing the attachment bolt is the bolt is mechanically in parallel with the piezo crystal. If the bolt is too loose, or too tight, the centre frequency of the sensor can be incorrect, so the sensor might pickup the valve train noise rather than knocking, for example.
Also, as the knock sensor signals are very small, they are easily swamped by electrical interference and noise. The noise may be interpreted by the ECU as knock. I have ended up fitting metal braiding over the knock sensor wires, effectively extending the ECU metal casing all the way to the sensor, in order to shield out electrical noise in one particularly difficult case.
also man... these are the instructions i followed for restting ECU, keeping above 11kph
ECU Reset
On early MYs (especially pre MY97) the ECU retards the ignition when knock is detected, however, it is very slow to advance the timing again. An ECU reset will restore the car to factory default settings. This will remove any stored fault codes and restore ignition advance. It is possible to reset the ECU by following these steps:
Turn ignition OFF
Connect Read Memory Connectors & Test Mode Connectors
(jumper 5) [black connectors] – (jumper 6) [green connectors]
Turn ignition ON (engine off)
Engine Check lamp turns on
Depress accelerator pedal completely
Then return it to the half-throttle position and hold it there for two seconds
Release pedal completely
Start engine
Code is indicated by Pulsing lamp
If a fault is detected - Check ECU Code
If no fault is detected - drive the car sensible for a couple of minutes
i.e. until warm (do not run tall & do not thrash it!)
When the ECU has been reset the Check Engine Light will flash
If a fault is detected Check ECU Code
Turn ignition OFF & Disconnect Connectors
If there is a fault Check Appropriate Sensor
