sti ver6 boost
G-unit
yea man mine was sitting around 16 stock standard on my old v6 - altho mine had a vf28 standard. with ur vf23 that should have an ever more slightly better top end i wud say based on it being slightly larger
hopefully the new pill/solenoid does the trick for u bro
PS. HKS EVC are pretty much the best i have ever used - awsumly easy to set and holds boost super solid ;D
  • Replies 106
Cant find the pill, but that doesnt mean it aint there..so many tubes! What is the circular thing that looks like a oreo except its white and has foam? bits in the middle which is on one of the lines leading from the tee to the boost solenoid valve?
just a q: how do you know the actuator is good? i had a gtx with the internal gate flapping in the breeze and still made 11psi. connected the actuator up and wound the boost gauge out past 30psi and fucked it,
test the actuator with a mityvac or some sort of hand held vac pump, even a syringe will work.
have tried dv8ers boost pill and solanoid with no luck,still a massive 0.5bar or 7psi,have taken some more pics of the pipes etc,could it be that the blue silicone hose is 2 big?
and also my ecu,does anyone know about these?apart from been a zerosports ecu :)
 G-unit said:
ok will do, dun a ecu reset and got code 32,3 slow 2 fast, when the solanoid is bolted on the fat black hose on the bottom, is that not how its ment 2 be?
the one on the bottom of teh noid goes to the Turbo 'T" joiner (with pill etc) the one on the side of the noid (on a right angle) goes to inlet hose (the bleed off)
