Price of Platinum spark plugs?
  • Replies 55
I assume on my car ('99 SOHC EJ20) I'd use the PFR6G?
Is it true they are $25 from repco at trade price? Just trying to justify why I'm being quoted double that.
150k? Jeebus, it doesn't seem like such a bad investment - but I knew I could do better than that.
That was discounted too - was looking at about $250 for the set from Armstrong but got a bit taken off. I figure they are the same thing though - I like the guys but money is a factor for me.
Theres a new set of PFR6G on TM for $50 so I might grab those, I need to get a valve cover gasket set before I put them in anyway
The quoted life for Platinum plugs in a turbo Subaru is 50,000km (na is 100,000km). That is the Subaru quoted life expectancy.
I bought my last set for $25 each from Repco. I can't remember how much Subaru wanted for them.
i got some zero sports ones for mine, there were $37 each back when redline sold them.
they seemed really good. no idea what they were though hahaha.
-smurff
Guest S T  E Y E
platnum and iridium are way too over rated...they only last longer... best for conductability is ngk copper bcprs and i got 4 for 20 bux at ripco
Guest S T  E Y E
cold for a non turbo tho...they will work fine tho...less chance of pinking on a hot day...5s will burn hotter (oviously ...dur haha) therewfore theory says a 5 will make more power/drivability but more chance of pink
I got that set delivered - though I just put in a set of coppers as suggested by the factory manual for the car.
Only problem with the platinums is that the gap is wrong according to everything I've seen - though the car had a set of the same ones in there already - the car should be using 1-1.1mm gap.
If you have problems with a 6 in a standard N/A you have more problems to worry about. The heat range doesnt make any more power just less chance of fouling at low loads. Iv run Bkr7es in my N/A legacy for the past 10,000kms and havnt fouled them once, I ONLY run the 7s because I had a spair new set from my race car when I went to 8's.
