UPGRADING SIDE FEED INJECTORS
B4 2000
HEY GUYS, im in the look/market for new injectors for my EJ20K (V3/4 STi) engine which has the yellow side feeds.
what are my options for bigger injectors?? looking for (750cc-850cc ones)
i know that sard has 800cc side feed but is there spray pattern that good (they have 2 holes)
ideally i want to get the bosch 750cc as they have the best spray pattern i've seen so far but they are top feeds.
please don't just say get this or that, i want reasons for why i would get this or that. Also experiences would be good.
THANKS
  • Replies 65
Abdul, i run the sard 800's in mine. I think your familiar with my build and it goes really well. While im well within the capacity of the 800's if i meddle in E85 at any point they will max fairly quickly.
I think you can get IDC in huge CC ratings that have epic spray patterns plus really good idle so perhaps look into those.
Note sards also need colars which are $$$
Sorry i cant help with the spray pattern as i don't know.
Funky, ya familiar with your build and spent bout an hour last night on your build's thread as I'm hoping for similar numbers to yours. So from your experience you recommend the sard??, I've looked into them and they would cost me $1000 give or take a bit for both injectors and collars.
 pappu said:
top feed sti pinks 565 (decap to 800) with rails
$250
what abt them?
Yes thought bout that, but how reliable are deccapped injectors???
Also, what do I need to go from side feed to top feed? Rails only??
 B4 2000']
$250
what abt them?
from what i have heard from the members who have done it here is that yea rails are the only things needed
can someone confirm
as for decapped injectors perhaps some ppl who have used that can comment more
i know some ppl who have used the decapped pink in a non ej lol and works mint but perhaps some suby person can confirm better
yer that pricing is about right :) Shred in wellington can get them for you for a little cheaper if you want me to ask.
I've had no issue with them what so ever, for the power im running, or at idle. That said i have no proof or scientific data on what the spray pattern is doing.
car goes fast and has plenty of fuel with no issues is as technical as i can give you.
On a side note - the walbro is nearing the end of its legs in terms of what it can supply at my power. I need a Bosch 040 (i think thats the larger of the two 040 044) to pump to the engine from a surge tank - and the walbro to supply the surge tank. (the walbro copes fine if it doesn't have huge pressure)
What about de capped ver 5-6 yellows ? Would go straight into your rails etc as theyr side fed like you wanted . . Some for sale on here which were tested on a flow bench at 3 bar and pulled 870cc I believe it was . . . . Cheap option if that some thing you would be interested in ? I havent ran de capped injectors so I cant comment on them but I would like to hear as im looking into running de capped yellows in the near future
They don't fit straight into my rails, I'll need the V5/6 rails and make brackets for them but if I'm getting deccapped injectors then I'll go for pinks cause of better spray pattern
Thanks funky, from googling it seems ppl are generally happy with the sards. Ya I'm running walbro as well so hope it's enough, don't have surge tank tho
neither at the mo but it seems happy enough at all map points.
i dont think it will last forever though - i bet its working hard at the top of the rev range.
I will be surge tanking this year and sticking in a bigger pump supplying the engine. nothing like leaning out an engine - i've seen two engines suffer lean out - and i REALLY dont want that.
True that, as you'll be using your car for track days mainly but for mine, don't really need it as it's my daily and I'm a nana driver 95% of the time (heck, car hasn't seen full boost bout 2 weeks -bout 15psi-)
 funkytown said:
awesome mate! was talking about you on the weekend and thought you'd gone underground - will be awesome to see the rebirth of yours.
Haha, nah still here, just too lazy to post (I should update my build thread ae)
will take pics and vids (turbo whistle is just FAB) when I have time, busy with uni these days -in a physics lecture now lol, shhhh-
hi
um does ''de capping'' the injecters make them un reliable or anything? why doesnt everyone do it? sorry i dont know about this sort of thing so would someone please be able to enlighten me.? cheers trent
 Trent said:
hi
mainly because if you had a ver 7 you would need a re tune on the ecu or on something earlier you would need a link or something to be able to control the injectors being so big
 Trent said:
hi
don't really know the answer but i'd love to know as well, as they would be a cheaper option
oh and as WRXONP said, you need to either re-tune your ECU or get an ECU of some sort to get the best outta them.
 Trent said:
hi
reliability is unchanged
decapped top feeds have a decent spray pattern
decapped side feeds have a rubbish spray pattern, in fact they dont even have a spray pattern
both will work but economy is bad for the latter
Have seen decaped inj on other motors with no issues at all
I think suby Ppl R perhaps not too keen on retuning lol
But yea I suppose the principle is the same for decaped inj regardless of motor and on the ones I seen may have been non suby but they work very well
In that light I Wud say that it should be sweet for Subaru motors
One downside I have heard is thT spray pattern is change but I really don't think it affects much unless u start dining them close to max
Seems the sti pinks have no issues with spray pattern as that's the one I seen Being used
Hmm 880cc maxing out be Quiet a massive power curve lol
I'm sure there are some suby Ppl here that can give their experience on their use of decapped units
Guys ive used de caped V5/V6 and de caped pinks they run fine up 2 330kw on 98oct.
V5/V6 do fit into V3/V4 rails but u need the top hats and need bigger O rings and they good to go best cheapest option ive got a set for sale if u guys are keen ive gone to 1200cc i dnt need them anymore and a mate of mine had them tested at 4bar they ran something crazy like 1380cc open at 100% but i know people rate them at 850cc.
and dnt forget that the pinkys are top feed if you thinking of going that way.
 Trent said:
hi
if u de cap them u need to go for a tune maybe a aftermarket fuel reg and most people dont need that much fuel V5/V6 stock with a aftermarket fuel reg can pump out around 550cc thats more then u need to run 200 230kw and u dont really want to run any more on the factory internals but if u got a worked motor then am sure u wouldnt mine going that much bigger - so its not for ur every day driver to go decap for no need :)
R8TD_R, I've got the whole lot, aftermarket regulator/fuel pump, forged motor, big turbo, FMIC, twisted, link G4, etc. Pretty much Only the bigger injectors I'm missing which hoping to make 280+ kw atw. I want to get the best and not the chaepest.
oh thats mean ok now we talking loool :D :D :D then dont waste your time bro ive got these black injectors cant really remember what they where called but i know they are 1200cc they are sooooo good the end of them looks like its got a ball like a pen they made the car run sooo good at start up and they even better with fuel then the factory 1. bro i vote for those because it sounds like you getting up there goodluck man and ill try and find out what they called they were around $1000
