Bolt up cat-delete pipe for v7 sti - does such a thing exist?
I spent a decent while googling and searching and nothing available locally seems to exist.
Anyone aware of one?
Rage *appear* to do one as part of their "system" but I would be unsure as to whether that would bolt into the exhaust if that was the only thing changed
Rage does do one but it won't bolt up to factory midpipe, you'll need to get the flange changed. Rage is only designed to bolt up to other Rage parts. Also be aware that once you start changing intake / exhaust parts too much, you'll want to get the ECU re-tuned, otherwise it can run like poos. Not saying it will, but it may.
I waited almost a year until I had the money for my tune, until i installed my exhaust and FMIC kit, so I could get it all done at once.
my brothers car has a full exhaust and front mount and runs fine with stock tune
as long as u let the stock ecu controll boost then its mostly all right
tune of course is best thing to do but usually without it u will run ok (not get the best outa ur setup) but by no means will it blow up as the v7 ecu is fairly well setup (rich afrs anyway)
do the mods
then save for a tune last
in the meantime u can still drive it fine..
PS. scooby - ur spec c should be pulling way harder now after tune eh bro!
Which sucks because their old 2 1/2 inch gc8 pipes do bolt straight up to a factory exhaust, 3 inch is a different story though.
 WRXONP said:
any one have proof ? that's ridiculous . . cat delete for the win all day
http://www.wrxtuners.com/forums/f51/catalytic-converters-cats-emissions-testing-emissions-cels-you-25335/
http://www.clubwrx.net/forums/engine-modifications/134325276-attn-02-05-wrx-owners-importance-uppipe-mod.html
Can't really provide solid proof as such, but it seems to be true.
 Timmah']
Beware the differences between USDM and JDM/NZDM spec cars though. I have no proof that they had Cat's in their up-pipes and the cars we see here didn't but I have a faint and distant memory of something like that being the case.
