Fair price to pay to get headers fitted.
Hi guys, just wondering what a fair price to pay is to get factory headers fitted onto my v7 sti as I don't like the sound of the equal length headers. Will I be needing new gaskets or not? So far have been to Magoo mufflers and been quoted around $275-$300 and I supply gaskets. Also if anyone has a business they can recommend in Christchurch for the job. Thanks
hmmmm nothings ever easy, have a mate who has a hoist and what not and has done a bit of work on Subaru's, its just finding the time to do these things that's the problem as one of us is either working or he is away rallying. Thanks for the info though.
 chappell943 said:
So where would the best place to be for genuine gaskets? Im guessing Armstrong Subaru in Christchurch? And turbo gasket and two exhaust gaskets?
Get a Quote from them, and also from Crowesport and Stubaru. Someone may have them cheaper while still being genuine Subaru ones
completely different story with a head gasket . . you of all people should know that ? my exhaust manifold has come off about 10 times . still original gaskets . just use high temp silicone each time . . there's 40 Psi pressure inside my exhaust manifold and no leaks . . . . just stating that you can re use them fine . .
thats why they dont leak you could throw the gasket away and use sealant and achieve the same thing.
each to there own. :)
I've re-used both of my turbo gaskets, up-pipe gasket and exhaust manifold gaskets and I have no leak issues.
Doing the headers... if standard ones will bolt up to whatever up-pipe is in there then it's a quick and relatively easy job, hardest part will probably be getting the O2 sensor out without breaking it...
If you need to do the up-pipe as well then it's a pretty big job, as mentioned you have to pull the downpipe, turbo, then the up-pipe. So probably a couple of hours and a lot more mess since you would be removing coolant and oil lines from the turbo.
Sealer on exh gasket pre turbo is asking for turbo failure
lol . just like silicone on rocker cover gaskets ? it is possible to get enough on to seal up but not enough to squeeze all into the exhaust ! and you can leave turbo on and change up pipe . . . depends if you want to take it off and use more time bleeding coolant etc
