spark plug gap size
  • Replies 142
 WRXONP said:
u can get a factory gap of 0.8 or 1.1
pretty sure BKR6E is gapped to 0.8 and bkr6e-11 is 1.1 gap
but better to check the gap as they can get knocked around in the box
A+++
I run 0.7mm gap for 19psi seems to work ;D
I've would rather put secondhand pfr6g's in than bkr6e lol
I wouldn't use any plug other than a pfr6g not even a bkr6evx
 WRXONP said:
BKR6EIX is iridium
i used bkr6e on 20psi .. no knock ran sweet.. but then again i do everything wrong :(
Could be wrong but Don't remember every seeing a BKR6E recommended for Ej20T/TT
That's good if a BKR6E works for you!! ;)
Personally i wouldn't be game enough to even try it
 sti8u said:
hmm cars seems to run alot smoother.BUT now my idel is messed up.idel hoes up and down like it has lumpy cams or something.hmm
air leak? hunting is normally air leak or o2 signal
and its fine to regap plugs if you know what your doing.i would never trust the gap out of the box
 WRXONP']
i gaped them to 0.8
nah no leaks that i can see/here.
idel is just up and down..
 WRXONP said:
o2 pluged in? u took air intake off to take plugs out yeah? got it all plugged up and not leaking?
cel?
yeh 02's in,and yup took intake off put i pull it off in one peice with afm,pod and joiner all atached.defnilty not leaking,.
