spark plug gap size
  • Replies 142
Sounds like air leak to me.. check the intake hoses haven't split.. the ones coming off the manifold and fuel reg are prone to splitting.. also you don't ''see a air leak'' you could however hear one if you have the right air, or you could grab a can of engine start and spray hoses etc to find the leak when engine is running as the engine start or 'ether in a can' will increase the idle when its sucked in ;)
yeh dam just drove it.idel is crazy!
its almost not ideling.
car runs fine and boost fine.but just sitting in the b.k drive thru the ideling got crazy.
also im starting to smell coolent from that back canester by the radiater
k here is some pics of the engine bay.
the nly things that were removed was the intake,battery,washer bottle.all hoses are hooked up correctly.
iv removed the intake again.and pulled it all aprt to check for leaks,but doesnt seem to be any
Uploaded with ImageShack.us
is there anything iv missed?
 sti8u']
[quote name='sti8u said:
hmm cars seems to run alot smoother.BUT now my idel is messed up.idel hoes up and down like it has lumpy cams or something.hmm
air leak? hunting is normally air leak or o2 signal
and its fine to regap plugs if you know what your doing.i would never trust the gap out of the box
i put same plugs in my car 3 weeks ago and they were regapped buy seller. i have the exact same thing happen to my car. more so when it is cold just sounds like it has a very small miss that makes the idle go up down slightly
i gaped them to 0.8
nah no leaks that i can see/here.
idel is just up and down..
