Boost spike after MBC install
kris_pran
Its been a while since ive been here :-X
Just recently bought a V5 STI w/ a rebuilt Fully Forged V7 Short block and V4 Heads/VF24 Turb.
Apart from the engine the car has an aftermarket 3 inch exhaust from the mid section but still running the restrictive factory downpipe, HKS Bov and a shitty pod flilter with a decent heat shield beside it.. Apart from that everything else is stock.
Before the installing the mbc, factory was holding boost up till 18psi constantly. This is my 2nd sti and i have fitted a mbc a few times. After the install took it for a spin
1st - 18psi
2nd - 18psi
3rd - 15psi after 4000rpm spikes to 20psi :o
Stopped testing after that lol.
Checked for leaks and loose hoses. Nudda nothing everything was tied up.
MBC is the problem?
They work perfectly fine, i have never seen any defects to them. Had them hooked upto my previous 360hp evo 8 held boost at 24psi all day long. Before that i had one on my version 4 sti that held 18psi.
For some odd reason this one decides to spike on 3rd and after, 1st and 2nd are holding up fine.
Ill upload a picture of how its hooked up soon.
Apart from the engine the car has an aftermarket 3 inch exhaust from the mid section but still running the restrictive factory downpipe, HKS Bov and a s***ty pod flilter with a decent heat shield beside it.. Apart from that everything else is stock.
1st - 18psi
2nd - 18psi
so why did u install 1 when its already holding 18psi?
that is a sh!t boost controller
get a decent mbc
i bet u had a better one in the 24psi evo??
i have had a older turbosmart boost tap and it didnt have issues like that
yes there was a slight overboost but maybe like a pound or so
compared to a electronic controller it wasnt too bad and near the same results (boost curve measured on torqu performance dyno)
anyway...get a better controller man
that one is sh!t...
hey man were about is that top hose going to?looks like everything else is right
also sometime the taps are the wrong way round.so mayb do abit of swaping n stuff.
btw internals wastegates are crap for holding boost.
go external or buy a decent ebc
Internal gates are fine, stop trying to cause an argument
control your hi performance engine with a proper computer (link,motec)
These cheap bits designed to increase boost just lead to premature engine failure..
Of course if you have heaps of cash and would rather buy or repair engines than have a proper computer tuned for the best performance.......Fit the cheap bits!!
