Yep its come up to the expensive one.
Which garage would anyone recommend in Christchurch, that used original parts and new how to treat a Fozzy STi SG9.
I have heard Stubaru is good.
Any advice welcomed.....
armstrong subaru did mine for a little over $2000. thats the full cambelt change and 100,000k service. very friendly and professional people and only took 1 day to do. would recommend
Holy crap @ price
(In typical Armstrongs fashion)
most garages will do it using gen parts if u ask, but 1200 seems to be a good price
Lets see the usual suspects like
RD
Stubaru
Autotech
etc...
Search function here for CHCH and servicing would give you more threads than you can poke a stick at
Nearer 20k, but don't want the the heart to go pop..... and I guess if you want to keep the performance you need to get the work done right...
Fair point.
My estimates are way out lol
Got mine done today at crowe sport
Labour - 5 hours @ $75 = $375
Timing belt - 1 @ $118
Tensioner assembly - 1 @ $185
Toothed idler bearing - 1 @ $57.70
Smooth idler bearing - 1 @ $67.50
crank seal - 1 @ $16
oil pump o-ring - 1 @ $4.20
Cam seal - 4 @ $16 = $64
Water pump kit - 1 @ $140
Materials - $6
GST - $155
Total= $1,188.41
  • 3 weeks later...
Finally got it done by Stubaru, seemed to know what he was doing also had all the oils changed, and air filters which were in a poor state, air con now works a treat just in time for the summer. all in all $1,600, bit more than I wanted to spend but overall happy with a comprehensive job.
Water pump was starting to leak as well....
