Engine Detonation :-(
3 kms difference? i dont understand the way u word things lol
if its detting in high revs - it sounds like its leaning out
clean afm - check plugs (heat range) - spark blow out (large gap) wont cause detonation - it will cause a miss fire
leads / coils wont cause detonation - they will cause misfire
detonation can be from lean mixtures - or timing too far advanced - or hot intake charge - theres alot of things
  • Replies 80
evowrx: Is yours nz new model with the upgrades (no speed limiter, 260k speedo, orange airflow, yellow injectors and 4 pot front calipers).
They run 1 bar factory. A standard JDM v5 non STI runs 11-12 as they don't have the supporting mods.
mines import too. yellow injectors 180kmh speedo with cut, 2 pot brakes. think td04 internal pressure was 12psi. my forester was exactly the same with yellows speed cut 180kmh. both phase 2. the forester was 12psi standard.
think you confuzzled - ver 5-6 run insert maf - no orange maf
 wrx_lou said:
Its been covered multiple times on here.
Nz new are different and do use an orange maf.
Use the search function.
The upgrades stated are factory options that were available on nz models.
fail ^^^ ;) maybe pre v5 bud. v5 is phase 2 quite a bit different. i know what im talking about for the first time in my life lol :D
 evowrx']
hahaha im sure ur more knowledgeable than what u letting on ahah but yea v5+ have inserts afm and wrx/sti
are pretty much same
 pappu']
exactly same afm by my research even by genuine part number.
i think he just needs a link/engine management so he can tune it sooner or later you will need to. will get more out of the car and better gas bill too. my set up is far from standard now and seems to run fine no det that i can hear. hell rich though but all about to change.
 madmike said:
So new coils and leads and it's running good...
So what you had was not det.. You had a missfire.
didnt gary capper tell him was det....?
he would know the difference between misfire vs det.... well most decent ppl wud lol
but seriously tho, big difference between the 2 (maintanance issue vs OMG engine will die at any moment of boost)
You would think so a.....
Aparantly in the thread gary told him he was using headphones.. So i'm assuming he had a knock sendsor on it and heard what he thought was det..
Not sure how he heard that when it was a missfire but hey...
it will only produce black smoke when it miss fires -
a turbo car should black smoke on WOT (IMO) as black smoke will come from the exhaust at around 12.5:1 and under AFR
IMO a turbo car that doesnt black smoke is too lean - but alot of black smoke is too rich (robbing power)
 WRXONP said:
a miss is far from detonation -
scare tactics perhaps hahahah
i have heard that cheap wof places do that to scare ppl into getting things replaced at their workshops as a possible wof fail.. similar sorta trend maybe..altho i dont really think it should be the case...
