Engine Detonation :-(
Just got my Boost tee installed/dialed in and goes good however the guy said to me that in the higher rpm 5800 to limit that the car is "pre detonating" i need help with this i really dont wanna go through another motor can someone offer some advice:-)
  • Replies 80
 evowrx said:
do you need to run a pill with the tap? it shouldnt have any problems at all i thrash the f*ck out of mine at 14.5psi no problems ever if i keep it of 15psi
Note to self, do not buy your car when it pops up for sale
Insert Quote
How many kms on the car? Proably something else causing it to detonate. check the voltage at your fuel pump with the car running? Maybe the pump not flowing enough at full boost
unsure of that i just got given the motor as a swap out from Sub-a-Roo cause the previous one went boom. **ITS NOT THE BOOST CAUSING DETONATION*** i will check that out mate how do i go about that :-)
at 11psi should not boost
keep the boost tee mate (especially if u spent a bleeding 200 on it..)
if they say its det - then when is it - at full boost of before or only certain rpm
could be a few other things as pointed above
also, if say u lower boost to say 9psi does it still det
ring that guy ask him what he meant and what was causing it. whats he define as pre det?
was it doing it before? if it wasnt doing it before at the same boost pressure without controller whats different now?
so he just told you not to go over 5500rpm or whatever? if its got problems at 6000 its probably likely not running right down low as well just not noticeable. gary capper im guessing, cant say he did something wrong would pay to get in touch with him when you can and get his advice hes one smart cookie.
