Securing Brake Hoses
+1 on cable ties... For my fronts i chiseled the mounts off my old struts (they were rooted beforehand), drilled them out to accept a bolt though them, then bolted them up to the existing mounts (v7 sti struts)
Rears are clamped in the holders with a cable tie as added security.
whats the legal requirement and wording around mounting? My own understanding was that you had to have a solid mounting point. Like what fozzie did, and what I've done.
Thats assumed though not having read the legal requirements.
For things like brakes, and having them fail - its bothering scary and i wouldn't scimp under the 'she'll be right' mantra. Do it right the first time imo.
Just says reason for rejection:
17. A flexible hydraulic brake hose (including connections):
a) is leaking brake fluid, or
b) is insecure, or
c) bulges under pressure, or
d) is twisted, stretched or chafed, or
e) has external sheathing which is cracked to the extent that the reinforcing cords are exposed, or
f) has metal connections which are excessively corroded, or
g) has an end fitting which is not attached to the hose by means of swaging, machine crimping or a similar process (Note 3).
http://vehicleinspection.nzta.govt.nz/virms/in-service-wof/general/brakes/service-brake-and-parking-brake
 funkytown said:
are those different to certification LVV rules or documentation?
LVV Cert Threshold guide says that no cert required for aftermarket brake hoses as long as it meets VIRM. It doesn't say anything about brake hoses whatsoever in the suspension category as pertaining to replacing struts, so one could reasonably assume either:
a) Brake hoses should meet VIRM for WOF but otherwise no problem because not mentioned in suspension section of cert threshold; or
b) Brake hoses could be assumed to be aftermarket (even though they're not) because the mounting point has changed / disappeared , in which case they are not required to be certed as long as they meet VIRM
So as long as they're 'secured', in essence.
So i thought id change my mounting setup before cert this thursday and ill show you my before and after setup
Before with cable ties
After with hose clamps
Definitely looks and feels alot safer than before and hopefully passes cert.
