mate has some 2pots rears that i can have for a sweet price so i wana know how others have fitted them? and where if possible do i buy the kits from?
my car is a version 5 with the 4pot front singles rear
cheers
you need some v7/8 WRX rear hubs. OR the adapter plates.
AFAIK the standard v3-6 sti you have is r160 so this is why you need WRX not STI hubs. v7/8 WRX hubs fortunately are still r160 but have the correct spacing for 2pot rears :) )
The adapter plates bolt up to your factory hubs.
either way you obviously want the 2pot rears + the rotors. your factory brake lines bolt up :)
so my factory rotors arnt the same size either?
we tryed the 2 pots on a 93 wrx ra and they were the same as mine, he has a 94 wrx with ver7 running gear so were unsure wat i need
also what do 2pots usually sell for? these look mint sort of a dark grey colour
personally i dont like adapters.. they look a bit flimsey.. and i can tell you .. brake failure SUX ballz...
adapters do seem to work though.
AFAIK they are different rotors. but just measure them dude.
what price - NFI
now to find some adaptors for a quick fitment as my singles keep sticking
hopefully some one will know wat there worth
^ what he said
STI v5/6 with sliding calliper rear brakes have tiny 266mm rear rotors.
STI RA's, v7/8 WRX and others that use the Subaru 2-pot rears have 290mm rotors.
so looks like if i do go ahead with this ill need new rotors to match also
do i need to adjust anything else or is it rather basic to swap ie- brake adapters,new larger disc's and 2pots??
cheers for the info
