trackday brake fluid
Guest STiEVO
Guest STiEVO
got a trackday what do i need for brake fluid. need to know by tomorrow so i can book it in to get replaced on friday . cheers
get the silicon valvoline shizz... its not hygroscopic and it has 3 times the boiling point of 5.1. its expensive tho... 60 bux for a litre.
Guest STiEVO
sweet how many liters do ineed ?
 STiEVO']
bout 5-700 mls depending on how much you flush thru... and you have some spare
Guest STiEVO
 Optical said:
use motul rbf600, everyone who tracks their car does and it's good stuff.
$30/500mls from bnt, racebrakes etc
a full system bleed is about 500mls, but to be safe prob bled through a bit mroe than that
so 1 ltr will be enuff then .will go to bnt tomorrow and book it in somewhere for thursday/ friday.cheers guys much appreciated
Stick to a good glycol fluid like Motul RBF600 or ELF ETX115.
Don't bother with silicone fluids, they are a waste of time and money.
-While they do not absorb water they do not stop water from entering the brake system and can allow water to gather at the lowest points in the lines, promoting corrosion.
-Silicone fluids are more compressible than glycol, leading to a spongyfeeling brake pedal.
-You can't mix silicone fluids with glycol fluids.
-Not compatible with most ABS systems.
motul rpf600
used that on the track and swear by it - they are really good and even with my pads smoking away, the feel was cosistant and there was really good breaking as far as spongy pedals go..
dunno the price but as quoted above they are not bad..
i had my entire system flushed - took like just over a litre ...
fully recomended bro!!
Guest STiEVO
just bought 2 litres of rbf600 for 80$ inclusive. can take any i dont use back. the guy recommended it gets a good flush to flush the existing fluid out.silicon vs synthetic or something to that nature.
dude that is cheap!!! yea a full flush be the way to go!!
will def see major improvements for sure
Silicon fluid is for extreme racing vehicle that are highly serviced.
it's only benifit is its boiling point
Silicon fluid attacks the rubber seals causing them to swell over time (usually only a couple of months)
The Super Saloon i crew on we change all brake seals at the start of, and again twice during our 6mth race season
Silicone Brake Fluid (DOT 5)
Non Hygroscopic -Does not absorb water- thus eliminating corrosion and deterioration.
Dry boiling point exceeds 600 deg.
Compatiable with DOT 3, DOT 4, and foreign brake fluids.
Compatiable with natural and synthetic rubber compounds.
Never needs replacement.Doesn't harm painted surfaces.
Lubricates moving parts.
Simple changeover - just perform normal brake bleeding job.
Packaged in 8 oz., 32 oz., 5 gallon and 55 gallon drums.
what seals are you using?
Using std seals for Tilton cylinders
I'm very interested in the fluid you mention, What brand?
Interesting also that silicon will mix with std fluid !!
A good dose of marketing BS there...
While silicon fluid does not absorb water it does allow it to pool at the low points of your hardlines, where it can cause corrossion.
It might not eat rubber parts but silicone fluid can seep through micro-fissures not big enough for glycol fluids to escape through.
Never needs replacement ?
So your boss never changes the fluid in his race car ?
:D
i agree. he does change fluid but, never had a problem with seals.
it may be different from glycol to silicone but that is the exact stuff he uses, comes from U.S.A and is relatively cheep. he uses AP brakes so maybe they have a different compound seal Rick?
Still interested how it can mix with gycol based fluids
Have you tried mixing the two in a bowl?
Have never heard of this fluid, an funny that they say it doesn't harm rubber compounds (all silicon I have seen does)
Maybe they are onto a winner
no but i will do first thing tuesday morning... im pretty interested in it myself now.... if it dont mix... firstly i appologize to you and then send a long email to the company that sell us this product.
also i have 5.1 dot brake fluid? is that much different that dot 5? he had to bleed through a good amount of brake fluid as i had boiled it and it smelt wrong then he put in the race fluid and bleed the brakes.
the brake fluid i have now is clear as and the braking difference is noticeable but that could be the new rotors/pads as well.
I also hope i haven't used the wrong fluid.
