Upper Engine Clean advice please
Hollow
I\'m just about to do an upper engine clean on my N/A B4 but I\'m just not sure of the best place to inject the cleaner.
The can says to \'remove a convenient vacuum hose from the intake manifold\' but I can\'t see an obvious one to remove...
Would it be better or easier to remove the pipe coming from the air filter and spray in in through the throttle body?
Here\'s a pic of my engine to give you an idea of what I\'m looking at...
Thanks for your help!
 soopersubaru said:
Where the breather returns to the plastic pipe pre throttle would be better...............Injecting into where suggested will only "dose" one cylinder.
Why are you doing this anyway?
brake booster hose is a bad idea... like I said... the other I suggested is fine...
 loner']
Brake booster hose is after throttle YA DORK
Breathers are before throttle.................ALSO if you dose through brake booster hose..........IT will only dose one cylinder..........AND as suggested will probably hydralic the motor too!
The hose you suggest is also NOT ok!
 soopersubaru']
Hey dude, how about you save the insults for when we meet face to face...
Also, read my post, I said the brake booster was a bad idea... and the other point is fine...
 loner']
OH OOps! sorry about the brake boost comment.................BUT you are still WRONG.........The place you suggest is NO good either.
ANY time YA like ..............Gloves off or on.................Gloves on make it easier to kill.................Thats a fact.!
I just dont suffer fools..................And idiot comments just wind me up.
AND you did suggest using the brake boost hose in your first post on this topic...........BUT changed your mind to an equally stupid location.
Humor me; what do you mean by "gloves on make it easier to kill?"
I wasn\'t advocating violence... I merely meant that if he saved his insults until we were face to face... then most likely there wouldn\'t
have been any insults thrown at all... pretty sure he\'s not going to call someone he barely knows a DORK to his face... but maybe he\'s
a rare case and is as obnoxious in real life as online?
 BC5RA']
Always up for humour!........Its a fact.......When boxing gloves were introduced......Boxers got killed and fights lasted longer.
Prior to that in bare knuckle days..................... fights were until the opponent gave up,...... Death was very rare.
Mr Loner......As you are 6 years old............Be assured i would not pick on you....with or without gloves.
However i will take you down when you are wrong about what you say!.....Quick smart everytime.
Just as others crap on into me!
Personally I dont Give two hooots what others think/say/do...........Just get it right if you comment!
 loner said:
dude, the location I first mentioned is fine... the brake booster hose I mentioned and disregarded in the same post... next time I\'ll just delete it...feel free to "come down hard" or whatever...
Loner is right. My N/A BH has the exact same engine, and I put UEC in the line he suggested next to the alternator and it worked great!
Btw soopersubaru you look like a fool when you start throwing threats around so lets all chill out.
 Hollow said:
Is this the one you mean?
The above indicated injection point for upper cylinder cleaner is a waste of time and product as only one cylinder will get dosed.
Anybody that disagrees with this ......................HAS absolutly no idea what they are talking about.....
Best place.............AS already stated by myself is ...........PRE THROTTLE....(end)
