2.2 piston question
bc5rs
 funkytown said:
Compression will be up the s***. As will dish shape depending on head and valve combo.
Also rods and psitons from NA are very weak for turbo application
But you could...
What difference in the metal composition would there be compared to na pistons?
compression ratio is 9:5:1 I think you just wouldnt want to run large amounts of boost on the factory pistons .
tuned correctly it would be fine .
I have some 2.2 rods from when I stripped one down but never noticed a difference, but never looked to close.
there was a high compression build on here a while ago and worked pretty well. power came on early
Whose was the build?
Theres is about .5 c/r between the V5/6 sti gasket and the V7 sti one isnt there would that bring it back to 9? I know very unorthodox but...
